need help troubleshooting my 907ie
Re: need help troubleshooting my 907ie
I noticed that the kickstand sensor wire was broken... I soldered it back on...??? cut off switch???
No, just a gear indicator. Light = no gear.
Sprag has nothing to do w shifting.
+1 on the checking ex valve guide, not uncommon problem, had it, too.
Stingray230SX
Post by Stingray230SX »
i used the spring from the oil seal trick to repair my sprag issue, been working ever since, going on 2 years now
doug
1992 907ie #1473 Nero SOLD
beekeeper
Post by beekeeper »
I checked the valves.... the vert exhaust is/was so tight, as bulls ass @ fly time!
I'll have to sand down the shim :huh: :smoke:
can I use any valve guide? there wasn't any play, but would like to get a spare set for future use....
I dunno if I read too much into it, but, take a step back, your standing on my Jewles! :shock: :mad: :lol: :lol: :lol:
I don't drink when I ride the bike. Dunno what that has to do with my bikes problem,either. I must have missed something. :?::)Joke? stab? text is lifeless...:roll: :fart:
:idea: The 12 pack I was refering to was COLA.... :drunk: ;) :lol: :lol: :lol:
I do drink while riding the keyboard from time to time :shock: :wacko:
I brew my own beer, honey mead & Rum here @ my home. 8 bux for a good/dank beer @ the pub is Hwy robbery! not to mention that the men to women ratio, lacking to my orentation. :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Yeah, its hot as hades here @ the lake too! it was 107 on the 4th.
my sweat was sweating!!! :lol: I had to put the sprinklers on my beehives, the comb was melting & dropping onto the hivebody floor :oops: :,(
Any comment on "wetter water" coolant additive?
Thank YOU ALL for the info & comments!!! Amusing & informative!
keep the greasy side down!
Jay the bee guy
samandkimberly
Post by samandkimberly »
beekeeper wrote:
I dunno if I read too much into it...
Meant entirely as a joke. I like to drink, I like to ride, but I avoid the combination, myself.
As far as the valve - if yout opening clearance if zero, how loose is the closer?
and RE the valve guides- in the US go with Kibblewhite. Don't be surprised, though, if the valve is burned up too.
Sam
93IE
Post by 93IE »
Run a compression test on it to see if the valve does have damage. I checked mine when I was having a problem, About 118 psig per cylinder. Good enough for me right now.
Preston
beekeeper
Post by beekeeper »
Sori, I havent gotten back sooner, I thru my back out moving beehives on the almond orchard... I'm supost to still be in bed.... going crazy, just laying there!
thanks for the diversion!
both the opener & closer are @ 0. Still don't understand how they effect the sprag...
anyone explain?
regards
93IE
Post by 93IE »
if the motor misfires while the starter is engaged, it overloads the sprag. I can't think of another way to put it. Starter turnining engine clockwise, misfire pushes motor counter clockwise, overloads sprag assy. :dunno:
beekeeper
Post by beekeeper »
Got it all apart in 30 min. Yeah the spring is shot! The previous owner said he had it replaced by Southern California Triumph.( I have the recipts)
I noticed some shabby work, to say it lightly. the spring had several streches & wasn't even atached.. or able to be attached.. the wrong end was cliped! A-HOLZ !
also their HOBO replaced several of the retainer screws... must have dropped/lost them, they are all boogerd up... Where the 5mm allen goes in is all spun out, I don't know If I could remove them with out a tap & dye... :mad: :evil: :twisted: :mad:
They have a "holyer that thou" attitude, & skoffed @ me when I called to bring it in.
The Jack-abacuses said they don't work on the paso, like it was a hodaka or something.
They are freaking Ducati mechanics for hells sake. They agreed to do the valve adj, after I gave them a PO for the work they had done 2 yrs ago... $600 for the adj.
BS I said, what if I bring it stripped down.... Oh NO we don't work on stripped down bikes.
I told them to pull their head out & wipe the stinky ring off their neck.
Sori, went on a tangent... :wacko:
what was the oil seal? I'm headed to the auto parts store...
THANK ALL OF YOU GUYS !!! Wish we were all a bit closer, so I could drop off a few bottles of honey mead to ya!!!!!
Is there any type of Paso show or meet up? I know the Moto GP in Monterey Calif....
regards!
93IE
Post by 93IE »
I can't find the seal number, but it was a 50mm Chicago Rawhide. Make sure you put sprag back in for correct rotation. Arrow facing you, ccw rotation
beekeeper
Post by beekeeper »
I didn't use any special tool to pull of the retaining nut.
I rotated the flywheel & used a screwdriver. the handle I put in the sub frame & rolled the flywheel until the edge of the screwdriver wedged in one of the flanges on the flywheel. I'll post a photo or link to my facebook page.
I'm using a drop of locktight on the threads before tork'n it down.
whats the tork? think I saw somewhere here ... it's 140 fp????
it didn't seem to be that tight when I pulled it off, seemed more like 80fp... but an 18 inch breaker bar may have created an illusion...
I marked it before removing it... I didn't notice any arrow. It should spin freely backwards, right...?
No problem,
I took it to the parts store & found one that is perfect. it's just a bit thicker
than the one that was broken. It fits good tho! $8.. I order'd 2 extras for my parts stash.
MFG by: Parts Master
Distributed by: Aftermarket auto parts alliance, San Antonio, TX 78258
PT 4539H c/r 23450 vic 48166
thinking that the c/r & vic numbers are the 2 parts that make the complete seal.?
going to sand down the valve shim on wet sand paper, I bought 600 grit for the major removal & 1000 for a final polish.... might even use the buffer & some "Mothers" rubbing compound
She should be waking up the neighborhood around 11pm :lol:
Looking foreward to riding her up the mountain!
I WILL drink an $8 beer @ hells kitchen, if I make it there.... :thumbup: :beer:
They have GREAT sweet potato fries. Mmmm!
Going to park right up front where the harley doods park :fart: :lol:
beekeeper
Post by beekeeper »
she fired and ran great in the center stand. when I put a load on her she ran like crud.
A new vibration as well.
I opened up the valves again, just to make sure.... YEP the valve guide is blown out.
thinkin it's partly from the valve being adjusted to tight & being old.
I don't know why Ducati used bronze valve guides...
Back to square one.... :dunno: :,(
Luckily my old boss has one he's selling for 1grand...
I'm going to try & talk him down to $600 & sell off what I don't need to cover the cost...
Anyone need anything for you bike???
