Page 2 of 3
Re: Straight Forward 750 Paso Project? ebay USA
Posted: Sun Jan 17, 2010 6:46 pm
by dewjantim
ducinthebay wrote:yes, matching paint on an older paint job is always difficult, but REDs are the worst. They have a nasty habit of fading over the years. Matching paint to what it looks like today will result in a mismatch in a few years.
http://forums.ducatipaso.org/posting.ph ... f=1&t=3834# You are much better off repainting the entire bike, or doing something complimentary. If you are talking about the air scoops, the easiest would be to do something complimentary, like an Italian flag, faux carbon fiber, or just a nice metallic grey. Or just cover it with lots of stickers.
I was thinking about maybe a white stripe on both sides and painting the bottom green instead of black.... of course then the whole bike is almost painted.....the flag idea sounds intriguing...
Posted: Thu Feb 04, 2010 9:58 pm
by dewjantim
Well, I have tried a couple of times to get the turn signal lens from the dealership in Louisville, Ky. Apparently Ducati has a new parts system and it isn't working too good right now so they can't see if it is available or not. Will try again at the end of the week. I think I will try the torch red on the air scoops and see if it matches. If it doesn't... Air Tech has some cool ones in CF which I may check into. It says on their website that they will make anything they sell in CF. They make some cool parts for ducatis.... including Pasos. If you order a lot they will deal also. They gave me about $500 off my order for my 900SS bevel replica bodywork..... good guys to deal with and the parts are reasonable. My brother said the tires are cracked on the sidewalls so I will need some tires also. I may try to order the Avons mentioned elsewhere in this forum.... even though I am eyeing those sticky Maxxis tires , if they make one which will fit. Well all my other parts are in and I am just waiting to go to Daytona to pick it up. Will update when I get back with some pics......Later...Dew.......
Posted: Fri Feb 05, 2010 1:31 am
by Desmo_Demon
dewjantim wrote:Well, I have tried a couple of times to get the turn signal lens from the dealership in Louisville, Ky.
If they are giving you issues, contact Myer's Motorcycles in Asheville, NC (
www.myersmotorcycles.com) and have them order the lenses and mail them to you. I've had at least one other person order them from Myer's from this site, also. They've usually been pretty good about ordering things and mailing them.
Posted: Sat Feb 06, 2010 10:03 pm
by dewjantim
Thanks for the tip.
Posted: Sun Feb 07, 2010 2:14 am
by Desmo_Demon
dewjantim wrote:Thanks for the tip.
If you continue having issues, just let me know. I can always order them and mail them to you, also.
Posted: Sun Feb 07, 2010 6:24 am
by dewjantim
Thanks......
Posted: Fri Feb 26, 2010 2:56 pm
by dewjantim
Posted: Sat Feb 27, 2010 5:04 pm
by persempre907
dewjantim wrote:Well, I have tried a couple of times to get the turn signal lens from the dealership in Louisville, Ky. Apparently Ducati has a new parts system and it isn't working too good right now so they can't see if it is available or not.
It's enough you ask for 907's lenses.
The 907 is already on their new parts system, so they can check about the availability.
Posted: Sat Feb 27, 2010 6:01 pm
by dewjantim
persempre907 wrote:dewjantim wrote:Well, I have tried a couple of times to get the turn signal lens from the dealership in Louisville, Ky. Apparently Ducati has a new parts system and it isn't working too good right now so they can't see if it is available or not.
Good to know, if I need anything else I will give call them again......
Posted: Sat Mar 06, 2010 3:40 pm
by dewjantim
I went to Daytona on Sunday and got home on Friday morning with my new (to me) Paso
. Yesterday evening I removed all the body work, got out the cleaning materials and went to work
. The primary cleaning took about 6-7 hours. Using diesel fuel and a stiff brush I scrubbed all the old dirt and accumulated grease from the chassis, engine, and wheels. Hosed the diesel fuel off and completed the cleaning with Suzuki cleaner (I buy it by the gallon) and a soft brush. Bodywork was also cleaned the same way. Blew the whole thing dry and installed the bodywork. Touched up some of the chassis and controls with black paint then shined it with finishing compound and armour all. Reinstalled the bodywork, hand rubbed it and sprayed with detailer for that oh so wet shine
. The bike is looking great. Today I will install the starter, new battery, and possibly the front tire (the rear is brand new, no cracks, with the tits still on the tire), touch up the paint, detail the chassis a little more, and maybe change the oil and filter. Hopefully it will be running by tomorrow
. If everything goes well I should end up with about $2300 in the bike and it will look fantastic
. Wish me luck...... more reports and pics will follow next week in the saga of the $1500 Paso.....Ciao for niao......
Posted: Sun Mar 07, 2010 1:30 pm
by persempre907
Posted: Sun Mar 07, 2010 11:16 pm
by dewjantim
I will try and get some pics on Monday and post them
Posted: Tue Mar 09, 2010 1:59 am
by dewjantim
Today I took the seat to be reupholstered..... red and black with green welt, a little pricey at $150 but the guy does a good job. He has done several seats for me in the past. Should be done by the end of the month. Also ordered the air scoop for the left side oil cooler today from Airtech, I was going to try to fix the old one but it fell apart when I unscrewed it from the fairing
. It should be here by the end of the month also
. I touched up the paint with the torch red paint and buffed it out with my high speed buffer. It matched pretty well even though you can see my touch ups from about two feet away. My wife said it looks nice and she hates motorcycles so it must be OK. I also purchased some green and red paint for the bottom of the fairing and the oil cooler scoops. Will mount my starter tomorrow and see if it works
, if not
.... I will try the wiring fix..... wish me luck
. Didn't get pics today, but will try again for tomorrow.....ciao for niao.....
Posted: Fri Mar 26, 2010 4:50 am
by dewjantim
Not moving as fast as I wanted but getting ahead slowly. The oil changed, belts changed, timing set, starter installed, new battery, new front tire, wiring connected (correctly I hope), new air filter, cleaned fuel filter, new fuel line, painted the bottom fairing, put on white and green pinstripes, and am the process of cleaning out the tank. Have to change the fork oil. Next is adding tank sealer and putting bodywork back on with my new stainless bolt kit. I have to go to Pennsylvania this weekend to pick up a couple of GTLs which I bought in February, so....... It should be running Monday.... still keeping my fingers crossed
Posted: Fri Mar 26, 2010 10:24 am
by higgy
Bring your waders,more rain
