Page 2 of 5
Re: Cam Timing
Posted: Mon Feb 08, 2010 10:07 am
nice pictures, thx
Re: Cam Timing
Posted: Mon Feb 08, 2010 11:40 pm
by jcslocum
Very nice pics and write up. I'll add it to the FAQ's for each froum tonight.
Is there and optimum setting OTHER than the factory setting that we should shoot for??? Something advanced??
Re: Cam Timing
Posted: Wed Feb 10, 2010 11:08 am
by higgy
Any info on adjustable pulley and where they can be found?
Re: Cam Timing
Posted: Wed Feb 10, 2010 11:16 am
by Duc906
I looked into getting a set from Vee Two but they are not making anymore parts for ducati's.
Re: Cam Timing
Posted: Wed Feb 10, 2010 10:58 pm
by higgy
Re: Cam Timing
Posted: Fri Feb 12, 2010 4:49 am
by jpitz31
I did some searching on the web,
This is what I found for adjustable cam pulleys. I do not know much about this company.
The price looks good and they offer both lightened alloy and aluminum pulleys.
Anyone have any more info on these folks?
http://www.corsemeccanica.com/ducati_timing_pulleys.htm
Joe
Cost & difficulty of getting tools for cam timing suggestion
Posted: Sat Feb 13, 2010 6:55 pm
by romus
Would these tools just suit the 906 or would they work for any Ducati?
1. For me and maybe others my knowledge is not enough to be confident to get the right tools sorted for this job...
...but If I could contribute to costs I would be happy to go in a pool with others and wait my turn. Imagine 10 people in a pool $150 each, would that cover costs Or, pay to lend tools for a month.
3. Or a post which summarises the tools and where to get them.
Also while the instructions in this thread so far look very good, I would need even clearer instructions to be confident to do the job. ie some background explanation and how to use adjustable cam pulleys, importance of secondary questions like cam belts and shims etc.
I'd be keen to do it and maybe others are like me.
Re: Cam Timing
Posted: Sun Feb 14, 2010 1:03 am
by jcslocum
Warwick,
The tools are not all that expensive and they will fit any modern (pantah and later) duc. I can work on instructions as I have done it before (long time ago) and borowed the tools. It's not a hard or difficult job, just tedious. Finding the pulleys or offset keyes can be tricky so having them on hand when you do the work will allow you to button it up right away.
Re: Cam Timing
Posted: Wed Mar 03, 2010 10:11 am
by Duc906
Just ordered a set of adjustable pulleys from VeeTwo. They are selling the last of their stock on ebay.
http://cgi.ebay.com.au/Vee-Two-adjustab ... 48398f40b9
They have 7 left in stock if anyone is interested. This will make adjusting the timing heaps easier.
Re: Cam Timing
Posted: Wed Mar 03, 2010 11:41 am
by romus
Duc906 wrote:Just ordered a set of adjustable pulleys from VeeTwo. ...
If I got a set what other parts would i need to do the job?
Re: Cam Timing
Posted: Wed Mar 03, 2010 12:05 pm
by jcslocum
romus wrote:Duc906 wrote:Just ordered a set of adjustable pulleys from VeeTwo. ...
I have seen them cheaper on ebay.....
You need the engine turning tool. On that allows mounting of a degree wheel. ~$75 here in the USA
A pointer and a piston stop.
A Degree wheel
Like this one: ebay 200440633752
Re: Cam Timing
Posted: Wed Mar 03, 2010 12:31 pm
you may also need the tools to remove/mount the cambelt pulley (like these 310200801509) or you do it by yourself
As I`ve learned, other than on a 750 you don`t have to change belt or lower pulleys which makes it a little easier.
PS: degree wheel
http://www.bevelheaven.com/downloads/Un ... ngDisc.bmp
The VeeTwo cams are relatively cheap. Ca. €250 incl. shipping. That`s about half the price than what I know aftermarket cams usually cost.
Re: Cam Timing
Posted: Wed Mar 03, 2010 5:28 pm
by ducinthebay
I just talked with Nichols Mfg. who also does service on Ducatis. I'm bringing in my ST4s for service and he offered a new service of installing their new adjustable pulleys and doing a valve timing adjustment. Since I'm doing belts and valve adjustment already the cost is pretty low. I'll let you know how it works out.
their pulleys are for 1999 or newer. I don't know if they will make pulleys for the older models. I'll ask when I take the bike in.
Re: Cam Timing
Posted: Wed Mar 03, 2010 11:12 pm
by Duc906
romus wrote:If I got a set what other parts would i need to do the job?
Hey romus, If you want when I get my bike sorted I could lend you my tools.(Pm sent) After all the work you did on the weber doc and the advice that you have given I'm more than happy to return the favour. I'm in the process of putting together a PDF doc to detail the proceedure for timing one's cams, I've been tied up with work a bit lately so it's taking longer than I expected.
Re: Cam Timing
Posted: Wed Mar 03, 2010 11:17 pm
by Duc906
jcslocum wrote:I have seen them cheaper on ebay.....
I got mine a bit cheaper too. Haggling is sometimes worth it.
