paso750 wrote:Pistons are more or less the same,and any OEM or aftermarket (wiseco/ferracci/pistal) piston for SS or Moster 750 will fit the Paso 750.
Here I would have to disagree. They do have the same 88mm diameter but they are not the same. The compression ratio is higher.
What`s the difference in the crankshafts ?
Of course is higher, most of the aftermarket pistons (if not all) are!
going by memory the lowest was the PISTAL RACING (Italy) @ 10.5:1 CR but it hat a T type of mantel (racing design)
The Old pistons have Flat Tops, the new ones have domed tops, BUT, they will fit.
Of course if you choose a HC piston you weill need to check the valve cleareance, but it is a very simple job for a good mechanic.
I had to machine a little away of the valve pockets as my NCR cams have very high lift an EXTREME overlap, so there was a little interfereance.
here is the comparison between the old piston and the Ferracci I decided to use; the white cast is to show the volume available in the heads (compression chamber)
As for the CRANKSHAFT, the main difference is in the NUT on the CLUTCH side; Unfortunately I do not have a picture of the PASO version, but I have one of an M600 which had the same measurements (stroke is 61.5mm as in the 750 and lenght plus all the main bearings diameter were the same )
Last the Gearbox
here is a picture of the one I had compared to the M620 version (on the right)
The old (Left) was from an elefant 750 (same as Paso just a difference in the gearing).
From the picture you can see that the primary has a different NUT, plus it has a hole which allows to install the Clutch slave cylinder on the left.
The secondary are exactly the same BUT different in legth; I am not sure if the Paso is longer than the Elefant version I had, what I know is that by using the M620 version, my rear sproket is perfectly alligned to a 916 rear end I fitted on the bike
Another thing, the selector drums are very similar, BUT they are NOT interchangeable; The selector forks, instead, are absolutely identical.
here is a movie of when I started the engine the VERY first time
http://www.youtube.com/watch?v=C3K4Yax8T8c
and one after a little tinkering with my FCRs BUT NO Ignitec Ignition yet
http://www.youtube.com/watch?v=n_MD_HWHe9A
I then fitted the Ignitec which helped a lot but still have to put it on the dyno, for more tweaking and testing, which I will do sometime this winter.
