Ok, so here are a couple of data log plots from my 750 paso
they are both taken from the same piece of road at about the same pace
for comparison purposes.Rpm is shown at bottom air fuel ratio on left.
all of the pink spots are different moments during the particular ride.All of the spots above and to the left of the top yellow line should be disregarded as they are from deceleration.
the first one is pretty much standard jetting
57 idle,150 main,170 air corrector and custom e-tubes
the things to note here are the yellow line bottom left showing the air fuel ratio dropping to below 11 and closer to 10.5,at 10.5 the engine will be stumbling particularly at higher loads and lower revs.
the other upper line shows the air fuel ratio approaching a lean miss,anything above 16 could cause a hesitation,particularly in the 5000-6000 rpm range,this plot doesn't show many in that range .The main problem here is the rich stumble caused by the 57 idles being too big.
the second shows the effect of dropping to 55 idles with a 165 main and 160 air corrector and custom e-tube.This is one of my better combinations.There is not a lot of difference between these two plots,but you can clearly see the
air fuel ratio no longer spending much time down around the 10.5 stumble zone
a few times the air fuel ratio has crept up to 16 whilst accelerating slowly,this can be seen near the centre of the top line,this is the lean zone between the transition to main jets and the engine only spends a split second there but this is where it can stumble if you place too much load on it,especially if it gets above 17 afr,with this combination of jets it only happens while the engine is warming up.It should be noted that the above combination behaves the same.
the difference between the two setups to ride is quite significant.Because of the leaner idle jet I find myself selecting a gear higher than with the stock setup,with plenty of power to accelerate out of corners without feeling like you are labouring the engine,the only drawback is I keep reaching for 5th now when I'm already there
This third one is a 55 idle 170 main 160 air corrector combination which also works very well.It is not from the same section of road as the other two.A rich miss is quite noticeable bottom left,but no hint of a lean problem,I will be working on this combination trying to eliminate the rich problem and lift the whole mixture just a bit leaner by .5 to 1 AFR. I will probably try a 54 idle first and then increase the main by one size if needed.Another scenario would be to
try a main in the 167,168 range,I have a drill about the right size,but don't want to bugger up my 165 main jets until I'm sure I've tried everything else.
As I said earlier a rich problem down this low in the rpm range isn't a real big deal,as it is a bit high in the revs to effect taking off from standstill and a bit low to effect general riding,it is only usually encountered in first and second gear so would probably be a pain in the ass in traffic conditions though.
one other thing that I have found helps a fair bit in smoothing out the on off throttle response is to set your idle speed adjust screw,so that just a tiny bit of the first transition hole is exposed.You can tell that this has happened by slightly adjusting the Idle speed up until when you rev the engine it takes just slightly longer to return to idle,(I mean ever so slightly longer),if you go to far you will lose too much engine braking.the sweet spot is at about 1400 rpm on my bike.I know that this goes against what the books say,but it works well.I know it takes away that really lovely sounding lumpy idle,but selecting neutral as you slow down also becomes easier !,and I hate the sudden surge of power as you accelerate in low gears mid corner.
I'll be doing some more testing this weekend. Jay.
