Re: chain
Posted: Sat Jul 02, 2011 6:50 pm
streetsurfer wrote:I saw the small bend to it mostly as an indicator that it had had an impact which may have raised the exhaust a little, in turn raising the center stands resting height. You may gain a quarter inch or so by straightening the bumpstop, if that. As mentioned by another a larger rubber insert may be a good solution. You don't want to crack the shell of the silencer during the bending so be gentle.
Thanks. Appreciate it.
