ECU availability
another CDI alternative
http://www.hpi.be/
http://www.hpi.be/applistlist.php?write ... =CDI&clr=c
The only CDI we have for Ducati and Cagiva is the black unit with a 2 pole connector and a 3 pole connector (CD6901D).
Prices:
Programmable CDI - single curve: 177€ ex
Programmable CDI - 2 curves: 232€ ex
USB interface + software: 175€ ex
The 2 curves options allows you to program 2 different curves into the unit, and switch between these curves using a switch button on the handlebar (switch button is supplied by us)
2 CDI units required.
Re: another CDI alternative
Interesting stuff, thx f sharing!
Re: ECU availability
the Silent Hektik modules (and the terrible Google translation)
They are not programmable but have 16 preprogrammed ignition curves than can be selected with a microswitch (4 each for 750cc engines, 900cc, 750cc with dual spark, 900cc with dual spark)
http://translate.google.de/translate?sl ... c_M-SS.htm
http://translate.google.de/translate?u= ... =&ie=UTF-8
Digiplex replacement
http://translate.google.de/translate?sl ... c_Digi.htm
