I need a little DIY maintenance help.
seanery
Re: I need a little DIY maintenance help.
Post by seanery »
I've changed the oil and filter and get no where near as much oil in the system as the manual calls for. Is the max line checked warm? Cold? Running? When running it looks lower than max so i could add more, but when sitting its at the line.
Ideas? Suggestions? I'll be happy when I've learned all the oddities of this bike!
92 Ducati 907ie
72 Porsche 914 2.0
did you check with the wheels on the floor, on the center or side stand ?
mh906evo
Post by mh906evo »
Hello seanery,
the oil level is measured with the bike not running, on centerstand, or in balance on wheels (thats only a very very little difference) If you fill over the max. it could be pressed out at the breather back of the horizotal-cylinder. So fill about to the middle of the window, thats enough.
Greetings,
Rainer
there`s currently one on ebay UK
http://www.ebay.com/itm/DUCATI-906-PASO ... 56470f7b44
