Why would the engine go to full open throttle just because the choke lever is missing, that makes no sense. It may revv high if the choke or choke cable is stuck open but even that shouldn`t fully open throttle. If the choke lever and cable are missing the only noticable thing should be that the engine is harder to start and keep at idle when cold.The observant amoung you may have noticed that the choke "lever" is missing from the handle bar so when she's started up she goes straight to fully open throttle!!
How no-one has blown it up yet is quite byond me.
Does anyone know if you can still obtain the choke "lever" assemblies for the 851 handle bars - (theyre probably the same as the 888)
