part swapping ?
- ducbertus
Re: part swapping ?
Derek,
just popping into my mind.
you need to make the studs firmly to the base plate. bests is to make the thread of the studs a little longer, so you can use a contra-nut to secure the stud. When you remove the head the studs MUST remain firmly in the baseplate. otherwise the accuracy is lost, just as your friend fears.
good luck, Bertus
good luck, Bertus
- Derek
- year: 1994
Re: part swapping ?
Bertus,
I'd thought of using the dowels from the cylinder/barrel joint between the baseplate and the head to maintain the accuracy.
- ducbertus
Re: part swapping ?
Derek,
very good idea. that will work as well.
I believe you'll master this.
Bertus
Bertus
- ducbertus
Re: part swapping ?
Derek,
any news?
Bertus
any news?
Bertus
- Derek
- year: 1994
Re: part swapping ?
Funny you should ask. I got the baseplate finished last night and I'm about to phone the engineer with the vertical mill today. Hopefully I will have it done in a few days.
- ducbertus
Re: part swapping ?
Derek,
I'm (we) looking forward to see pics of evidence your engineering skills!!
Bertus
Bertus
- Derek
- year: 1994
Re: part swapping ?
Bertus,
I didn't take any pics of the backplate before I took it to the machinist and since the 50mm thick alloy plate that I used belonged to him he'll want it back after the job's done, but I'll be sure to post a pic of the head with the finished conversion.
Derek
p.s. I got that pair of ST2 barrels and pistons too, so the 907 will be an ST2 under the skin by next spring
Derek
- blazing928
Re: part swapping ?
[/quote]
17 months old son, wife pregnant with some 50 days left...[/quote]
but this will be good later as they are close enough to play together.
i have daughter & son 18mths apart, well thought out job!!!
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
Lambretta LI150 S3
87 928S4
- Derek
- year: 1994
Re: part swapping ?
Bertus,
I now have an ST2 head with a tacho drive take off
- ducbertus
Re: part swapping ?
Derek,
very well done!!
thanks for the picture. I'm sure you'll enjoy that mod.
now the next question; will she run this year or are you preparing for next year?
I'm eager to hear your opinion about the results.
Bertus
very well done!!
Bertus
- Derek
- year: 1994
Re: part swapping ?
Next year Bertus, we had our first snow of the winter today
- ducbertus
Re: part swapping ?
hi Derek,
weatherforecast here predicts also snow, which means the end of a season with very little driving.
it'll be better next year.
bertus
bertus
Rhino
Re: part swapping ?
Hmmmmmmmmmm
Now - when I need my bikes altering where do I send them . . . to Derek or Bertus?
Rhino
If God rides a Harley . . .
Then the Devil rides a Duke!
- ducbertus
Re: part swapping ?
Rhino,
difficult decision. Derek is more or less in your area and showed evidence of machining parts
from me, on the other hand there are only stories......
I give a picture of a casting of a John Deere front axle hub. the rolling torque of the wheel bearings is set by machining the bearing contact surface to an exact set value. hard part of the job is getting it all square.
I was trained for conventional turning/ milling and CNC turning/milling and grinding.
when want me to machine parts, feel free to contact me
Bertus
Bertus
- repairing front axle John Deere tractor
- Afb112 - kopie.jpg (30.18 KiB) Viewed 7305 times
- Derek
- year: 1994
Re: part swapping ?
I just found that the ST2 horizontal barrels doesn't have the M12(?) threaded holes that are used to bolt the front lower engine mounts to. All it has is an M6 threaded hole on the RH to take a stud for fixing the battery box mount. I wonder if these lower mounting points are really necessary?
