Question about wheels
helge-seins
Re: Question about wheels
Post by helge-seins »
The rear 16" wheel will only fit if it is from a 750 Sport not if it is from a 750 or 906 Paso. The rims are identical but the rear axles aren`t (20mm Sport/ 17mm Paso) so the bearing spacers in the rim and also in the sprocket carrier are not the same.
Äh, Gerhard... die Sport HAT 17mm Achsen ! Ich habe ZWEI Sport `90... Und diese haben DEFINITIV 17mm Achsen ! :thumbup:
Äh, Gerhard... the Sport got 17mm Axle ! I own TWO Sport `90... and they got 17mm axle definitely ! :thumbup:
Thank you !
Ducati 750 Sport `90 #750924
Ducati 750 Sport `90 #751918
Ducati 907 i.e. `93
Suzuki VX 800 `92
Yamaha PW 50
BMW e34 520i `93
BMW e34 520i `94
sorry my bad. It`s the other way around. The Paso has a 20mm rear axle.
