Page 2 of 5
Re: New Project 907 evo
Posted: Fri Nov 09, 2012 8:53 am
by paso750
You forget that an SS Showa is shorter than a M1R.
Posted: Fri Nov 09, 2012 12:46 pm
by Tamburinifan
"I put showas on my 907 using SS yokes,"
Would really appreciate pics of that!
As G said, isn't their llength an issue?
Saw one on mobile, it was leaning forwards quite a bit.
Posted: Fri Nov 09, 2012 4:48 pm
by 900streetfighter
All described in upside down thread with newish pics. K.
Posted: Sat Nov 10, 2012 12:07 pm
by Tamburinifan
Thx!
Now I remember, HM legs-SS yokes :roll: :oops:
Posted: Sat Dec 01, 2012 9:54 pm
by JoKing
Good luck. We will see if you`ll have a clash between head & tank.
I cross my fingers for you.
I wanted to do a 4V-conversion, but ended with a 3V-Conversion, that was much easier.
Posted: Fri Dec 14, 2012 12:38 pm
by Speedmade
RĂ¼diger'
How is the project coming along? I am still interested in the shock from the 906.
Reed
Posted: Sun Oct 06, 2013 10:42 pm
by Bock900r
Hello Together,
I was busy for a long time, and will be again outside Germany until X-mas.
I was on rehab for some weeks and spend some days on the project.
Here some pics from the Evo.
Frame ansd Swingarm
With the engine
On Wheels - Distance Wheel - Zylinderhad is to small, S4R fork is to short.
Now with Multistrada Fork. Enough space for the wheel
Connect the wire harness on the bike.
Hopefully finish next January
Posted: Mon Oct 07, 2013 4:22 am
by 900streetfighter
Coming on well. 999 mudguard bolts straight on to Multi legs. I had to raise the radiator to get a bit more clearance. Does rear shock hook up to original frame mount?
Posted: Tue Oct 08, 2013 10:26 pm
by Bock900r
900streetfighter wrote:Does rear shock hook up to original frame mount?
No, Modify a lot
Posted: Wed Oct 09, 2013 7:22 am
by 900streetfighter
A 2:1 exhaust will show off that Swinging arm :)
Posted: Wed Oct 09, 2013 10:41 am
by Bock900r
Will be the QD Box below the Engine
Posted: Thu Oct 10, 2013 2:21 pm
by paso750
while that is one big project I will say I think that swingarm is really ugly and doesn`t go at all with the design of the rest of the bike, sorry.
I don`t think you can fit a QuadD box either unless you modify it a lot simply because other Ducs that exhaust is made for have the motor hanging in the frame. The lower part of the Paso frame will be in the way.
Where will you be fitting the battery ?
Posted: Thu Oct 10, 2013 7:32 pm
by Bock900r
The Batterie will be a Lithium Ion, small is easier to place, The Swingarm may get black. Exhaust Mods are a smaller problem or may be I use one from the S4.
He, If it will be too ugly, I take of the Monster parts and put the S4R together again and use the 906/907 parts for spare. Second Option: I change to a 907 Swingarm
I got another Bike in the Garage for some fun.
Posted: Thu Oct 10, 2013 8:56 pm
by paso750
you could use that as a donorbike for a nice swingarm :mrgreen:
The F4 is not in your list btw.
Posted: Thu Oct 10, 2013 10:29 pm
by Bock900r
I keep the MV as she is. Yes, she is not in th List. Also my last Kawasaki, a ZXR750 R K-Modell is missing
