Page 2 of 2
Re: As motor temperature rises, the idle speed rises???
Posted: Tue Jan 15, 2013 2:29 am
by ducinthebay
I'm pushing for an air leak too. My Sport had leaking intake manifolds, and the idle would rise when it got warm, and it just continued to get worse. The intake manifolds have o-rings in them that should be replaced if you ever take them apart. DON'T be tempted to use RTV to seal the intake. That will only last a short time, as modern fuels will dissolve them slowly, and your problems will all return. O-rings are measured by the ID, then thickness. Lots of places on the web to get them.
Of course, if your intake boots are stock, they are a common cause of an airleak also. Just see if the clamps are tight, and the bolts to the manifolds are tight would be a first step.
Can you get a CO measurement to see if you are running lean on one or both cylinders?
One odd ailment that some of the ST2s had was the water temperature sensor. if it went bad, it told the computer the motor was cold and richened up the mixture. While this is opposite of what you are experiencing, its another failure point.
Phil
Re: As motor temperature rises, the idle speed rises??? *FI
Posted: Sat Apr 06, 2013 6:39 pm
by st2sam
907pasonut wrote:hi Sam, just remove L/H side fairing and cable tie the radiator hose to the frame, away from accellerator shaft, as motor gets hot the rad hose expands and rubs agaist butterfly shaft (or whatever you call it)...simple fix, as I said on a previous post, I had the same thing happen to my bike (15yrs ago) but reving higher (3-4K) common problem with the 907 :thumbup:
Crumpati wrote:Check the coolant hose isn't expanding and pushing on the throttle cable, there is a post on here about it.
We have two winners! :thumbup: Thanks guys, your check is in the mail. :wink:
When I took a closer look at the fast idle (and throttle) area where it attaches to motor it looked like there was plenty of room. WRONG! There was about a 1/4in space that I thought was enough, looking closer I spotted a black mark on the fast idle arm where the expanding hose would rub and increase idle speed... :banghead:
I zipp tied the hose at that point to keep the hose from expanding and making contact, *PROBLEM FIXED*!!!
Now if I can locate a tachometer cable I'd be a happy camper.
Thanks again to all that offered help, this site is awesome! :beer:
Sam.
Posted: Sun Apr 07, 2013 1:08 pm
by 907pasonut
happy motoring :thumbup: :thumbup:
