Re: Speedo/Tach cables ... same thing?
Posted: Tue Jun 17, 2014 9:49 pm
or in the documents section of the main page.
fasterdammit wrote:Now why I hadn't I seen that before now? sigh ...
Thanks, G. Saving my butt like usual.
Parts catalogue, for those looking for it, located among other gems in the Paso magazine articles and other downloads thread.
paso750 wrote:In all the years I didn`t have any negative experiences with SD and if there was something to clarify I`d do it via telephone not email
On second thought, nevermind. I was able to grip the plastic section of the indicator shaft in between the tension spring, and the backside of the gauge face, and manually tweak the needle's base so that it points to 0 be default. I'm not convinced that it's going to give me an accurate reading (I'll forever question that tension spring now) but at least it will appear accurate at rest.I don't see any means to re-index the needle to zero, unless someone wishes to confirm for me that you can safely pop the needle off the shaft & reposition it? Or, do I need to separate the metal input shaft assembly from the white plastic spring/needle assembly and attempt to adjust from there?
