Page 2 of 2
Re: Oil Pressure Sensor Replacement?
Posted: Thu Sep 29, 2011 8:09 pm
by Stingray230SX
Googled the 69921511A p/n and it comes up here:
http://www.store.commoto.com/product_in ... s_id=71923
looks like we can get it for all our bikes?
doug
Posted: Fri Sep 30, 2011 9:38 pm
by jayh
Land Rover discovery TDI 300 is also a direct swap.Your local auto parts store should have a aftermarket catalogue full of senders and their switching modes and thread pitches,I just went down the list until I found the correct mode and pitch with a price that matched my wallet.
J
Posted: Sat Oct 01, 2011 2:51 am
by Mc tool
Mine is off a VW golf ..... I think . Like Jayh I wandered down to the local parts guy ( Jim @ Allparts ), perused the catalogue , 10mm taper thread , nc ,6.3mm spade & 7 lb crack.....mmm a Vee Dub huh. There were 1/2 a dozen that would have done if I could be bothered changing the terminal on the harness to suit , and I figured that the operating pressure wasnt vital as long as it was ballpark , I mean if you are supposed to have 60 psi it doesn't matter if the red light is telling you that you have less than 7 psi or less than 4 psi , either way your history.
If I set the idle to low the oil pressure light on my guzzi winks at me like a homo in the toilets ... probly harmless enough but unnerving all the same ( I can get it to idle at 4 -500 rpm ) and anyhow its not 1/2 as excitable as the charge light which blazes away at anything below 1700rpm .
fuck
I hope I havnt got them mixed up
I dont do italian
gen ... charge light , folle.... blinkers , luci ... neutral and olio for oil pressure..........I think
Posted: Sat Oct 01, 2011 6:38 am
by nojapan
Posted: Sun Oct 02, 2011 12:46 am
by delagem
Hi Doug, well, you could always buy the OEM part from Ducati as well. My point when I started this thread was twofold:
1. I didn't want to wait weeks or more for the part.
2. I didn't want to spend over $30 on a friggin' oil sender!
I don't know how long you've been a Ducati owner, but finding critical parts on semi-permanent backorder (Like oil filters! 1993? Anyone else here remember that one?) is enough to make me want to find alternatives any time I can. (EDIT: If Ducati NA ever runs out of oil filters AGAIN, go to NAPA and order a filter for a Simca. No, I've never heard of one either. But I've used an oil filter from one!)
I now have a section of my toolbox devoted to leftover sensors from this project! So much for saving money! Ah well, it was fun, figuring out a different way...
