Page 3 of 3
Re: 17" conversion - Weldup
Posted: Fri Oct 30, 2009 11:12 pm
by higgy
jcslocum wrote:ducinthebay wrote:Considering the challenge and the work of the weldups, $500 is worth the price. Now the bigger question, is your beloved Paso worth $1k to run on new rubber? The cheapest option is still the old way of using 4.5 and 3.5 wheels from a Monster/SS and become friends with a local machinist to make all the bits to fit.
We should work up the DEFINITIVE spec for using other wheels and the bits. I have a full engineering department that can do the drawings for us and spec the materials. Lets start another threqad on this to get exactly the right info and instructions. That way if it needs to be done, anyone can take the drawings to a local machine shop and get the parts made up.
Jon
If you have metrology equipment I have a set of extra wheels
Posted: Fri Oct 30, 2009 11:19 pm
by higgy
ducinthebay wrote:Yes, I think that is an excellent idea.
For the front you need the two brake adapters for either 4 pot Brembo brakes, a speedo drive for the new wheel, and machine (if I remember right) 5mm off the inside of the left fork leg.
For the back, I don't have a Paso, so I can't tell you.
Phil
I'm confused. Rotor changes and adaption I can understand. But what do brake adapters and fork changes have to do with making 17's out of 16 inch wheels? You lost me there
I really thought the idea was to K.I.S.S for all those Paso's and sports with 16 inch tire issues Or did I miss something,like a lottery win
Posted: Mon Nov 02, 2009 4:52 pm
by ducinthebay
Higgy,
I was answering Slocum's post about putting together a list of bits to convert a set of newer Ducati wheels to the Paso. Call it the Conversion Kit.
If we put that list together, and get it quoted from a reasonable machine shop, the speculation is that it would be less than $1k.
The ideal would be to have one shop make the entire kit, minus the wheels.
If anyone has all the files, I will talk to Jon Nichols, owner of Nichol's Mfg., who makes all kinds of nifty aftermarket bits for the Ducati. His quality is top notch, and I could probably talk him into making some kits. Now all we need is the BOM (bill of materials) and the CAD files.
I went searching on Bauke's site to get the CAD files for the brake adapters, but all of his links are broken.
Posted: Mon Nov 02, 2009 5:12 pm
Bauke got the files from me. they were the same that can be found in my download thread
Posted: Sun Nov 15, 2009 9:14 pm
by higgy
seems price of t6 aluminum plate is up a bit so will be more like 200 a wheel for material just a minor update
Posted: Sun Nov 15, 2009 10:10 pm
by higgy
I have today made an initial contact with an outfit today located in Delaware about converting our 16 inch wheels to 17 inch. Looking to keep an unfinished wheel in the 500 dollar a wheel range out the door. These guys also do finish work. What I could use some help with as I am currently working my arse off is what 17 inch tires will fit without any other mods but to the wheels. Any one had time to find the answers?
Will standard 17 inch tires fit 17x5.5 and 17x3.75 wheels and our Paos's or do we need a smaller width? No one I have found so far has any interest in converting to wider widths which I feel would defeat the purpose of a straight up taller wheel anyway as that would require many other mods. My idea is K.I.S.S. a simple bolt on conversion.
Posted: Mon Nov 16, 2009 6:09 am
by ducinthebay
Almost all modern motorcycles have 3.5" front, with a 120 tire, and a 4.5, 5.0, or 5.5" rear rim. The supermoto crowd uses 4.25" with a 150 tire. With the 4.5, a 160 tire is recommended. 5.5" rims usually use a 170 or 180 tire.
Posted: Mon Nov 16, 2009 9:34 am
3.50 and 5.00x17 would be a good size.
Posted: Mon Nov 16, 2009 10:59 am
by higgy
Cool,Thanks guys
Posted: Tue Nov 17, 2009 11:03 am
by higgy
Bummer. Got a reply today,the outfit I contacted is no longer interested in working with Motorcycle wheels outside of powder coating. Will have to try another.
Posted: Tue Nov 17, 2009 10:45 pm
by Desmo_Demon
I was just thinking about this thread yesterday while out riding my Paso. I noticed halfway through my ride that my rear tire is right at the wear bars. It's wearing fairly evenly from edge to edge, and the front tire is getting thin on the left and right of center. I'm disappointed that the tires only have 2800 miles on them, though. I was really hoping for a bit more than these are getting.
I tend to run my tires until they have bald sections or I see cords, so I'm only expecting another 500 or so miles before I need to replace them. If we can find a fairly inexpensive way to modify the 16" wheels to 17" diameters, I would be quite tempted to go that route. I do have almost all the parts I need for a 17" conversion, but I'd rather not spend the time on that when I have other projects around. I was thinking about just using an alternate tire size in the meantime, as some others have been doing.
