Page 3 of 3
Re: 1990 750 Sport Rebuild
Posted: Mon Mar 01, 2010 8:56 am
by paso750
Joe,
while you`re at it I`d also open the starter and check the brushes.
http://forums.ducatipaso.org/viewtopic.php?f=1&t=2573
Btw, seeing you pulling the rocker arm shafts. I guess you still have the old type. Newer Ducs (Supersport/Monster) have upper rocker arm shafts with a spring clip on (as far as I remember these are the same on 600/750/900), this makes changing shims much easier when adjusting valve clearance (just remove the clip and push rocker arm aside). I had mine swapped during the engine rebuild. No modification needed. I found mine on ebay for little money.
Posted: Mon Mar 01, 2010 5:57 pm
by jpitz31
Thanks G,
I pulled the starter in order to powder coat it, Now I will take it apart and check the brushes.
I ordered the rocker arm shafts, for $30.00 that is a steal.
Joe
Posted: Mon Jul 26, 2010 11:32 pm
by helge-seins
Hello Joe...
i would like to know...
your last Blog entry...
a few month passed by...
...hm, when will the story go on ?
:huh: :-(
Posted: Tue Jul 27, 2010 1:04 am
by spaynenda
Joe, I'm also curious...and by the way I live here in Escondido. Could we be neighbors and not know it?
