Page 3 of 3
Re: Starter problem
Posted: Sat Jul 30, 2011 12:47 am
by Harry
Well i head back to Sea this week for a month and the Paso is still sitting in the Shed with no go. It looks like im up for a new starter Sprag when i get back . Is this a job i could do at Home, im pretty handy with the Spanners if not i will have to find somebody here in Western Australia that would do the work.
Re: Starter problem
Posted: Sun Jul 31, 2011 9:57 pm
by Tamburinifan
Sounds like time to replace sprag to me.
http://www.mad-ducati.com/ShowPage2.php ... over2.html
Do clean threads on crank thoroughly, use correct Loctite & use correct torque on flywheel nut.
Re: Starter problem
Posted: Wed Aug 03, 2011 1:41 pm
by romus
Harry wrote:Well my Hicap Kit arrived and i fitted it to the Paso with no problems aside from a rusty bolt on the starter. So after fitting the above i went and hit the start switch and all that happens is that the starter gets plenty of juice but is not firing the starter sprag? out to engage. The starter solenoid is making a clicking sound when i push the start button. I hope this is not to confusing , but yeh im stuck for advice on what to check next. Any help would be apprciated.
This sounds a lot like the trouble I have, though it was Mmm a few hundred Ks after I fitted the Motolectric kit before my starting issues arose. Also randtcastell in this thread is stuck with a non starter even though starter motor turns over. So with me, you and randtcastell that's three with the same sort of thing.
I wonder if adding the Hicap Kit is so good in its kick power, it will kill off a sprag clutch (spring) that is near the end of its days.
Well, I did uncover other issues, like some dodgy electrical connections, replacing my solenoid and even the CPU (which they said was stuffed). I had some clunking develop after my continual attempts to start the Paso. What was left? - the sprag clutch.
So I have mine out, but am waiting for my new sprag clutch to arrive before I put it back together. I want to compare the old spring with the new, but the existing spring holding the sprag together does seem really sloppy stretchy to me. Well, if replacing the sprag does turn out to fix the starting, it may be it is a possible issue that comes to the surface with the extra kick that the new Hicap Kit gives- Just an idea.
Re: Starter problem
Posted: Wed Aug 03, 2011 3:41 pm
by higgy
The Hicap fix will not fix a basic starter problem. Sprag,and solenoid must be in working condition as well as the brushs.
It will however enhance a working system measurably :banghead:
Re: Starter problem
Posted: Thu Aug 04, 2011 9:13 pm
by Mobius
I made a slight modification when I installed my Hi-Cap starter kit. Instead of connecting the Hi-Cap cable to the frame, and then using the existing cable to get the power to the engine, I connected the Hi-cap cable directly to the engine after preparing the surface a little, and then installed the original (much lighter) cable to carry the power to the frame.
It probably doesn't make much difference, and I know very little about electrickery, but it seemed logical to keep the starter motor power going through the fattest pipe possible at all times.
Re: Starter problem
Posted: Fri Aug 05, 2011 12:08 am
by Harry
Yeh Mobius thats how i done mine. I got an e mail back from Mike at Hicap and it would seem that when replacing the starter circut with the Hicap it is not uncommon for an old Sprag spring to fail it must because of the increase in current flow to the starter anyways i am glad that the sprag shat itself when the bike was in the Shed and not on some remote Western Australian Road in 40 degree heat lol that would have been very sad indeed. Now i just have to wait out the month and get back and find a Mechanic that will work on the old tart :)
Re: Starter problem
Posted: Sun Aug 14, 2011 8:23 am
by Aart
Sorry Dutch
Revision from my startmotor with koperen lagers heeft lost my problem
No gel accu!!!
Aart
Re: Starter problem
Posted: Mon Aug 15, 2011 11:21 am
by Harry
Yeh Aart i cant follow what your sayin there mate :o
Re: Starter problem
Posted: Mon Aug 15, 2011 6:19 pm
by Aart
My 3 duc's 750/906/907ie
Groet Aart
Re: Starter problem
Posted: Mon Aug 15, 2011 6:29 pm
by Aart
My Laverda's
My dog's
I hope that you fiks the startproblem from the 906 fast.
Groet Aart from holland
Re: Starter problem
Posted: Tue Aug 16, 2011 5:32 am
by Mc tool
Harry wrote:Yeh Aart i cant follow what your sayin there mate :o
yeah ! what sort of lager was that ? mmmmmmm beer :lol:
Re: Starter problem
Posted: Thu Aug 18, 2011 1:40 am
by du907
I'm beginning to think it's the sprag clutch or the starter not turning fast enough. If the starter is turning fast enough not only will you hear the starter spinning but you should also hear the two or three reduction gears turning/clanging on that side too. If all is turning then it most likely is the sprag clutch. A little story: I bought my 907 from a guy and it only had 4,000 miles on it. It hadn't been in for the first service and oil change. As soon as I got it home I cleaned it up and changed the oil and filter. It would not start any more! I CHANGE THE OIL AND FILTER AND IT WOULD NOT START. I couldn't believe it! The starter would spin like crazy but not engage the sprag clutch. On these bikes the clock would run down the battery and starting the bike on a weak battery would make the starter spin slower and therefore not fully engage the sprage clutch which would in turn wear out the sprage clutch. Hince the reason people would disengage the clock. So, I had to put in a new sprag clutch, about $185 US at the time just for the part. But, I now have 50,000 miles on that same sprag clutch.
du907
Re: Starter problem
Posted: Thu Aug 18, 2011 5:53 am
by Mc tool
Sorry but I thought a sprag was a one way clutch that uses a cam locking action and therefore does not need to be spun fast enough to engage , rotating slowly by hand should be enough to lock it ( one way of course ) and if it doesnt lock solidly , instantly every time ..... it needs sorted
And I for one are going to get me a couple of these things to put under my pillow. I dont think they will ever be cheaper and I hope I need a couple before I give up riding :)
Re: Starter problem
Posted: Fri Aug 19, 2011 10:49 am
by Tamburinifan
Your thoughts are correct, it do lock turning by hand.
Re: Starter problem
Posted: Wed Aug 24, 2011 2:57 pm
by persempre907
Aart wrote:My 3 duc's 750/906/907ie
Groet Aart
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Very nice combo!!!!
Ciao :beer: :beer: :beer: :beer:
