Page 3 of 5
Re: New Project 907 evo
Posted: Sun Oct 20, 2013 10:55 am
by persempre907
Posted: Fri Jan 10, 2014 10:48 am
by Bock900r
Spend some time at my friends Bikeshop to work on the Project. I have enough overhours to spend some time home
Bought some time ago the yellow fairing, Tank, all Yellow.
Got all the cables and electric connections done. The Fuse holder is at the moment hanging down, need a good place
Posted: Fri Jan 10, 2014 10:53 am
by Bock900r
And the next Project is waiting
Posted: Fri Jan 10, 2014 12:56 pm
by 900streetfighter
That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
Posted: Mon Jan 13, 2014 7:37 pm
by Bock900r
900streetfighter wrote:That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
Oel change and may be change the volume is planed after everything is done. Your values are a good point to start with.
I placed the the Cat-Box under the bike
I will use a Akrapovic Shorty as Exhaust
Posted: Tue Jan 14, 2014 11:38 am
by 900streetfighter
Your rear arm looks about 50mm shorter looking at footrest/tyre position.
Probably be a hairy ride with 4v power.
Posted: Tue Jan 14, 2014 10:44 pm
by Bock900r
900streetfighter wrote:Your rear arm looks about 50mm shorter looking at footrest/tyre position.
I will measure the lenght from the swingarm bolt to the center of the wheel tomorrow
Today I shim he swingarm, install the rear break, tight the srews for the Kat Box
Posted: Wed Jan 15, 2014 10:54 am
by Bock900r
From the swingarm bolt to the center of the wheel is it 520mm to 540mm
Posted: Wed Jan 15, 2014 5:48 pm
by 900streetfighter
907 arm is about 585mm from ctr of pivot to ctr of adjuster slot.
Posted: Thu Jan 16, 2014 4:52 pm
by Bock900r
Change the Belt's today, fill the Tank. Push the button - running
Posted: Fri Jan 17, 2014 6:07 am
by persempre907
Bock900r wrote:Change the Belt's today, fill the Tank. Push the button - running
Let us know after the first flight!!! That bike will not run, she'll fly!!!
Posted: Fri Jan 17, 2014 11:37 am
by 900streetfighter
The way Rudiger is cracking on that will be soon
Posted: Mon Jan 20, 2014 7:16 pm
by Bock900r
I took the Original Cockpit from the S4R. Ididnt want to try to convert it into the Paso cockpit. Too much Electronik and too many wires
Posted: Mon Jan 20, 2014 9:01 pm
by 900streetfighter
What yokes have you used Rudiger?
Keith.
Posted: Mon Jan 20, 2014 9:11 pm
by Bock900r
I use some connection points from the Cockpit holder and use a aluminum plate to block the view and hold the cockpit
