capacity engine
koko64
model: other
year: 1999
Re: capacity engine
Post by koko64 »
paso750 wrote::mrgreen:
Holy Shit :lol:
Doesn't need a side stand!
2013 M1100 Evo Street
2004 GSXR750 Track
Re: capacity engine
Mc tool wrote:Holy crap G ! you sure don't look like what I expected :) er, nice bike :roll:
for age 44 I`m not looking too good. I had to cut the beard as it was constantly being sucked into the carbs :lol:
Re: capacity engine
Least G didn't have to worry bout a hair cut
Re: capacity engine
so it was running a bit hairy :?: :lol:
Brutus
Re: capacity engine
Post by Brutus »
This is also rather extreme.. :banghead:
sergiomala
Re: capacity engine
Post by sergiomala »
I'm not experienced in bevels, but i enjoy a good ride with my Paso, time to time. My clock reaches 210 kmh, that is quite a lot and enough to get my driving license torn off.
What i would ask to my engine is a bit more torque, not more power. I miss it out of the corners, or in case of overgetting cars or buses in mountain roads.
Increasing torque value is the same as to improve max power? I think it's a bit different, in my eyes. I heard about exhaust mods to increse torque output.
Anyway, compared with bikes same age 750 twins (guzzis) or 400 / 500 / 600 cc 4 cylinders, the Paso standard torque doesnt look so bad to me.
Ducati has a heart. Japaneses have a chip.
Brutus
Re: capacity engine
Post by Brutus »
sergiomala wrote:I'm not experienced in bevels, but i enjoy a good ride with my Paso, time to time. My clock reaches 210 kmh, that is quite a lot and enough to get my driving license torn off.
Bikeboy has written a couple of articles. Try this one: http://www.bikeboy.org/dyno.html
BikeBoy wrote:..To put it simply, Torque is the amount of work done and Power is the rate at which the work is done (or the amount of work done during a given time..
sergiomala
Re: capacity engine
I don't think there is a mathematic ratio between power, rpms and torque. On the dyno, the shape of the curves are often very different between power and torque. My 1098R has the max torque at 8.200 rpms and the max power at 10.500 rpms. Never dynoed my Paso. Pretty curious about the result, even if it's not so important.
Re: capacity engine
Post by jcslocum »
OK, there is ONLY a mathematical relationship be tween these things, HP is purely a calculation of Torque and RPM.
Calculate the horsepower.
Using the formula HP=(RPM * T) / 5252, determine your engines effective horsepower.
Example: A Porsche 911 generates 480 lb-ft. of torque at 2,500RPM. Expressed in terms of the equation, that is HP = (2500 * 480) / 5252 = 1,200,000/5252 = 228.48hp
If you look at your dyno graph, you will see that torque and HP are the same at 5252 RPM. Torque is the only measurement a dyno makes, the rest is all math.
Derek
Re: capacity engine
Post by Derek »
That is completely confirmed in Phil Irving's "Tuning for Speed" in which he says Torque= bhp X 5250 / rpm
sergiomala
Re: capacity engine
Thank you guys. i'm not an engine tecnic. So this graphic output is not possible? Didn't find my 1098R graphic, so this is a 1098S one, pretty similiar.
Edit: found the 1098R one
