Page 3 of 3
Re: capacity engine
Posted: Thu Jan 02, 2014 9:32 am
by koko64
paso750 wrote::mrgreen:
Holy Shit :lol:
Doesn't need a side stand!
Re: capacity engine
Posted: Thu Jan 02, 2014 10:30 am
Mc tool wrote:Holy crap G ! you sure don't look like what I expected :) er, nice bike :roll:
for age 44 I`m not looking too good. I had to cut the beard as it was constantly being sucked into the carbs :lol:
Re: capacity engine
Posted: Thu Jan 02, 2014 12:28 pm
by higgy
Least G didn't have to worry bout a hair cut
Re: capacity engine
Posted: Thu Jan 02, 2014 9:22 pm
by Mc tool
so it was running a bit hairy :?: :lol:
Re: capacity engine
Posted: Sun Jan 05, 2014 7:58 am
by Brutus
This is also rather extreme.. :banghead:
Re: capacity engine
Posted: Sun Jan 05, 2014 8:46 am
by sergiomala
I'm not experienced in bevels, but i enjoy a good ride with my Paso, time to time. My clock reaches 210 kmh, that is quite a lot and enough to get my driving license torn off.
What i would ask to my engine is a bit more torque, not more power. I miss it out of the corners, or in case of overgetting cars or buses in mountain roads.
Increasing torque value is the same as to improve max power? I think it's a bit different, in my eyes. I heard about exhaust mods to increse torque output.
Anyway, compared with bikes same age 750 twins (guzzis) or 400 / 500 / 600 cc 4 cylinders, the Paso standard torque doesnt look so bad to me.
Re: capacity engine
Posted: Sun Jan 05, 2014 9:29 am
by Brutus
sergiomala wrote:I'm not experienced in bevels, but i enjoy a good ride with my Paso, time to time. My clock reaches 210 kmh, that is quite a lot and enough to get my driving license torn off.
Bikeboy has written a couple of articles. Try this one: http://www.bikeboy.org/dyno.html
BikeBoy wrote:..To put it simply, Torque is the amount of work done and Power is the rate at which the work is done (or the amount of work done during a given time..
Re: capacity engine
Posted: Sun Jan 05, 2014 3:51 pm
by sergiomala
I don't think there is a mathematic ratio between power, rpms and torque. On the dyno, the shape of the curves are often very different between power and torque. My 1098R has the max torque at 8.200 rpms and the max power at 10.500 rpms. Never dynoed my Paso. Pretty curious about the result, even if it's not so important.
Re: capacity engine
Posted: Sat Jan 18, 2014 3:55 pm
by jcslocum
OK, there is ONLY a mathematical relationship be tween these things, HP is purely a calculation of Torque and RPM.
Calculate the horsepower.
Using the formula HP=(RPM * T) / 5252, determine your engines effective horsepower.
Example: A Porsche 911 generates 480 lb-ft. of torque at 2,500RPM. Expressed in terms of the equation, that is HP = (2500 * 480) / 5252 = 1,200,000/5252 = 228.48hp
If you look at your dyno graph, you will see that torque and HP are the same at 5252 RPM. Torque is the only measurement a dyno makes, the rest is all math.
Re: capacity engine
Posted: Sun Jan 19, 2014 12:08 pm
by Derek
That is completely confirmed in Phil Irving's "Tuning for Speed" in which he says Torque= bhp X 5250 / rpm
Re: capacity engine
Posted: Sat Jan 25, 2014 11:41 pm
by sergiomala
Thank you guys. i'm not an engine tecnic. So this graphic output is not possible? Didn't find my 1098R graphic, so this is a 1098S one, pretty similiar.
Edit: found the 1098R one
