Just a progress report up and running now comes the wiring up of sensors
details
Arduiino mega 2560/Speeduino/Tuner Studio
Plan to add bluetooth in the near future
What you will get is flexible and configurable fuel and ignition management that will work for the majority of every day type setups. Currently supported features include:
16x16 3D fuel and ignition maps, with base of either TPS (Alpha-N) or MAP (Speed Density)
Supports up to 8 cylinders fuel and ignition with 4 channels of fuel and 4 channels of ignition outputs
1, 2 (Even fire only), 3, 4, 6 (even fire only) and 8 cylinders
After Start Enrichment
Rev limiting (Spark based, hard and soft)
Cranking specific enrichment, dwell timing and advance
General logging through TunerStudio
High speed tooth logging
TPS calibration through TunerStudio
Sensor calibration through TunerStudio (Coolant, IAT and O2)
Warm Up Enrichment (WUE)
TPS based acceleration enrichment
Tacho output
Fuel pump activation/deactivation (With priming)
Over dwell and over duty protection
Battery voltage compensation for dwell and injectors
Modular wheel decoder support. Included decoders:
Missing tooth (Eg 36-1, 60-2 etc)
Basic distributor (Fuel only)
Open loop idle control (PWM and Stepper)
Open loop boost control
Open loop VVT control
Semi-Sequential or Simultaneous injection
Deceleration fuel cut off (DFCO)
O2 based autotune (Registered version of TunerStudio required)
Did I mention GPS will also be included
