Page 4 of 5
Re: Swapping wheels to 17inch
Posted: Sun Feb 28, 2010 10:44 am
by ducbertus
translation is superb.
for those who want to contact.
here is the phone number 0031 55 505 329
fax. 0031 55 505 2154
email:
info@startwin.nl
on the other hand I can help as well, because these guys are 35 km away from my place
Bertus
Posted: Sun Feb 28, 2010 1:20 pm
by PasoRoo
Hi Bertus,
Zelfs aan de andere kant van de wereld komt je moerstaal zo nu en dan nog van pas!
Mike
Posted: Sun Feb 28, 2010 1:45 pm
by ducbertus
just for the others, this is the last in Dutch to thank Mike for his quick translation. after that we return to the common English language.
Hallo Mike, ik was inderdaad verrast door de snelle en goede vertaling.
Dus ik vermoede dat iemand kennis van de Nederlandse taal of in de directe familie moest hebben. Normaal zou iemand zou gaan sputteren over het ontbreken van de vertaling.
thanks Mike
Bertus
Posted: Sat Nov 13, 2010 1:32 pm
by Dutchy906
Hi guys (and girls),
I've followed the topics about tires over here for a while and a few weeks ago, my tire problem got actual also (cracked front tire).
Just ordered these "halfrings", they should be here somewhere next week. Then putting the 906 on Pirelli.. I certainly curious how the handling will be in compare with the original Michelins
regards,
Rigo
Posted: Sat Nov 13, 2010 5:23 pm
by hardo
hi dutch 906
i swaped the michelins in sep. 2010 and decided to go for the avon azaro st 45 / 46 zr combination (130 / 70 and 150 / 80). I am not using the halfrings and hence there is not too much room left for chain adjustments.
however, it works perfect, i did 500 km so far and it is really amazing: a much better handling than before / conditions under breaking etc. had really been approved. i did go for this combinations as it has an approval from ducati germany and it is a zr rated matching tire pair.
i will come up with some pictures and additional information with a new thread whenever i find some time. all the best, hardo
Posted: Thu Nov 25, 2010 5:52 pm
by Dutchy906
Hi Hardo,
Do you have some pictures already ?
I tried the Pirelli's without the halfrings but the tire is too high, will touch the frame. With the halfrings I get enough play to get the wheel in...
best regards,
Rigo
Posted: Fri Nov 26, 2010 6:38 pm
by Xchoppers
Why aren't you guys going the 180/60-16 route?
Posted: Fri Nov 26, 2010 7:07 pm
by Finnpaso
Posted: Sat Nov 27, 2010 3:11 am
by Xchoppers
Thanks for your views on this Finnpaso.
I think you have explained the issues quite well.
Posted: Sat Nov 27, 2010 8:28 am
by Finnpaso
.. with poor english language!
Posted: Sat Nov 27, 2010 9:33 am
by nnnnnnorman
Posted: Sat Nov 27, 2010 11:21 am
by paso750
I too think a Paso belongs on 16" wheels. Here`s a 907ie and from this angle it just doesn`t look right. Specially the rear wheel looks too big. No doubt it may handle better, though. (btw the pic proves that the Contis also fit on a 907ie)
I think the era of 17" wheel conversions on Pasos is about over. The common reason to do this was that there were no tire alternatives which infact always existed. The 150/80-16 is what many go for although the tire is not made for a 5" wide rim. Ducati Germany approved it though. Although it`s a tight fit there`re about no modifications required except for lifting the front fender, a longer chain and turning the rear excenters way back. You lose most of the way to adjust the chain, but there are numerous sports tires in this size.
The 180/60-16 which is a perfect fit for a 5" rim requires spacing out the front and rear sprocket or the chain will hit the tire. Many 180/60s are for heavy tourers, only one or two manufacturers recommend their models for customs, sport tourers etc. one of them being AVON. I chose this option.
While I will stick to the 180 I guess in the longrun the 150/80 will be more popular as you don´t have to machine any new parts.
Posted: Sun Nov 28, 2010 9:21 am
by persempre907
you're right, perhaps the 907 does'nt look good with its 17" rims, even if I think also Pasos don't look so good with 180/60 16" rear tire.
Too big, too.
P.S. I have the same 2 in 1 Conti on my 907...
Posted: Mon Nov 29, 2010 3:23 pm
by paso750
true the 180/60 is big but it´s by far not as high as a 150/80.
Posted: Wed Dec 01, 2010 11:50 am
by micklm
Hello,
I went the 17inch wheel route - this way I have the same tyres and (almost same) geometry on my Paso and Supersport.
I have tried 120/60-17 with 160/60-17 and will switch the Paso to 120/70-17 to match what I have found works best on the SS.
And I think the 17inch wheels look better
Looks fine on my bike I think
Better details on my conversion here
http://forums.ducatipaso.org/viewtopic.php?f=2&t=4272
It was not so simple or probably as cheap as making different 16inch tyres work.......
I do agree the the photo of 907 (above) looks a bit funny - but I think this is more the black rims with black tyres and because it is sitting up on the centre stand!
cheers,
Mick
