Page 4 of 38
Posted: Sat Jan 07, 2012 1:30 pm
Can anyone give me any info on a 2-1 header system for the reverse head engines.I much prefer the look of the dual system but it would be nice to get her as light as possible.
Why would you even think about that? Corrosion already made your bike considerably lighter
2in1 headers for sale appear once in a while but not very often. I wonder if one for a Paso would fit, too. The 600SS originally only came with a 2in1 system, but I don`t know if that one would fit or if the tube diameter is the same.
Posted: Sat Jan 07, 2012 1:35 pm
by higgy
Lot of work to keep an alloy finish
POR-15 would be easiest and quickest. When it comes to bringing long neglected items back to life POR rocks and is very durable
Clean it, hit it with metal prep and paint it
They also make a product called Glisten for alloy finishes. I have never used it but hear it is an excellent product
http://www.por15.com/Clearcoats/products/6/
Posted: Sat Jan 07, 2012 11:59 pm
by Andrew2
Posted: Sun Jan 08, 2012 12:01 am
by higgy
Posted: Sun Jan 08, 2012 12:44 am
by Andrew2
higgy wrote:Lot of work to keep an alloy finish
Which POR-15 product Higgy?.I can't seem to find the right one.By the way I've started reading your Weber site.Bloody good info that.Big thumbs up
Andrew
Posted: Sun Jan 08, 2012 4:28 am
by higgy
GLISTEN PC™ is a Rock Hard clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces.
They also have great engine enamals if you want color
I use their chassis black almost everywhere, frame,handle bars, all those little black bits.................fairing screws.............
Since you will be on a 750 be sure to read jayh's stuff here............
he has pretty good results with his 750 just modifying the pump can.
Others have also followed his ideas and had good results on the 750's
Posted: Sun Jan 08, 2012 7:13 am
by Andrew2
Did'nt get a lot done today.A bit more paint removal and also took the exhaust system off.
I think there's potential here.Thanks G:thumbup:.
I'm going to clean up the garage tomorrow in prep for removing the motor.
A2
Posted: Sun Jan 08, 2012 10:55 am
Having several bikes you probably have a rear wheel stand. If so you can use that as a motor stand.
Maybe don`t use a hammer in front but something more stable
(found on the internet)
Posted: Sun Jan 08, 2012 8:48 pm
by Fraser
McTool,
The pear cider was a disaster, tasted like vinegar, complete shite. However, only have 33 l of it (48 bottles worth). Will have another go this year, have come across someone who makes it regularly, so with some expert assistance we should be good.
Fraser.
Posted: Mon Jan 09, 2012 5:05 am
by Andrew2
Fraser wrote:McTool,
Fraser.
Your shout then Fraser
Posted: Mon Jan 09, 2012 5:20 am
by Andrew2
paso750 wrote:Having several bikes you probably have a rear wheel stand. If so you can use that as a motor stand.
Good idea G.I might knock something up similar
A2
Posted: Wed Jan 11, 2012 9:07 pm
by ir_joep
On the 600 single exhaust I can tell the diameter is smaller compared to the system we have.
Good luck fixing your bike!
Greets Joep
Posted: Wed Jan 11, 2012 9:38 pm
by ducinthebay
...And I can tell you that the stock header pipes on the Paso and Sport are smaller than for later model 900 motors and aftermarket. Although I haven't tried it, the headers from a 900 motor should work, but you may have to trim the back pipe going into the collector. The angle at the exhaust flange seems to be unchanged, but the added stroke moves the heads a bit farther apart.
The one 2 into 1 exhaust that was made for the Sport was the Gia-Ca-Moto. I have one on my bike. I think Conti made one also.
If you search the aftermarket pipe manufacturer's websites, you can see how interchangeable their pipes would be.
For routing, anything that fits later SS models should fit the Sport. This is not true with the Paso, as that swingarm configuration lead to a very unique header pipe. Of course the rear hanger attachment would need to be modified, but that's easy enough.
Posted: Sat Jan 14, 2012 9:36 am
by Andrew2
Posted: Sat Jan 14, 2012 11:08 am
ok, you asked for it.
Go back out in the garage, look for a wire and tie that rear caliper to the frame - now. You may also replace that rag in the engines swingarm bushing with tape as the rag won`t really protect from dust.
Nice engine stand btw.
So what`s the story about the other bike, what happened ?
