Page 4 of 7
Re: swingarm chain slider
Posted: Mon May 05, 2014 8:14 pm
by plasmid
Anyone interested to do a run of the small chain sliders?
Posted: Mon May 05, 2014 9:30 pm
by Bock900r
paso750 wrote:looking good.
If the width is 28mm and the total length ca.22,7cm it should be right.
around 226mm long, 28mm width
Posted: Tue May 06, 2014 6:54 am
by Duc906
Bock900r wrote:around 226mm long, 28mm width
Hi Rudiger
Looks great
, those measurements correspond to what I had drawn up. I have emailed you 2 pdf files with most of the measurements for you to verify. I'm not sure why the scale changed when I changed the file to STL format but it looks like you have it under control anyway. I will have a play around with the software and see if I can make any sense of it.
Thanks again.
Posted: Tue May 06, 2014 11:49 am
by Duc906
Bock900r wrote:I was busy all weeks with our Metal machines and looked on Friday to the file - It was so small. I scale the part by factor 10 and a kolleg build me one in Black PA11
I am not shure that the Dimention is right
Got it worked out. When I saved it to a STL file the settings were in centimeters when they should have been in millimeters, thats why you had to scale it up by 10.
Posted: Tue May 06, 2014 5:30 pm
by a330us
Regarding the small center stand chain sliders, I could use several depending on price, lots of Paso's
Thanks Arch.
Posted: Tue May 06, 2014 9:46 pm
by Bock900r
With the STL for the little slider, I can make a lot, basicly for the cost of the shipping
I don't know the lifetime of these material with the chain in contact.
I must only build something on a Plastic machine, I am at the moment more working on the Metal machines
Posted: Tue May 06, 2014 11:45 pm
by plasmid
Bock900r wrote:With the STL for the little slider, I can make a lot, basicly for the cost of the shipping
Better than nothing.
I'd take 3.
Posted: Tue May 06, 2014 11:46 pm
by plasmid
a330us wrote:Regarding the small center stand chain sliders, I could use several depending on price, lots of Paso's
Thanks Arch.
But no photos
Posted: Wed May 07, 2014 10:37 am
by Duc906
The STL file for the small one is on it's way, I'd be happy to test them out.
Posted: Sun May 11, 2014 2:28 am
by Bock900r
I give the file to a friend, he will build me some Hnad Full of the small one and some more from the swingarm slider. Just tae some time, I fly home for vacation
Posted: Sat Jun 07, 2014 8:28 pm
by Bock900r
I found a noon running machine today in our Office
, load 2 large slider and around 60 small chain Slider into the machine
There was white Nylon12 on the machine, so all parts come out White.
Posted: Sun Jun 08, 2014 12:05 am
by Duc906
Great news Rudiger. Looking forward to see how they come out.
Posted: Mon Jun 09, 2014 7:27 pm
by plasmid
Bock900r wrote:I found a noon running machine today in our Office
Awesome!
Posted: Fri Jun 13, 2014 2:57 pm
by Bock900r
Back in the office today, clean out the parts
Is there someone local (USA) I can send some for testing if the fit before I make them again
Posted: Fri Jun 13, 2014 10:11 pm
by higgy
I'm in Pa, pm sent
