Connect it up and start cranking and no go for a few seconds then she fired into life
If you haven't already found it, I'd highly recommend Tygon hose. Really easy to work with, and lasts well. Not the cheapest stuff out there, but it's what I use on all my bikes now - https://nronketti.wordpress.com/2022/01/08/lux-prima/ to see how I got on with it on the 750.Andrew2 wrote: ↑Fri Jan 21, 2022 12:05 am <snip>
I will need to get some proper fuel hose as the car type stuff I'm using doesn't like the bend it has to do to clear the rear cylinder from the fuel tap. I could turn the tap a bit but I try and leave things alone that don't need fixing plus it would make it hard to turn the fuel off. I also don't like the look of the hose coming around the outside of the cam belt covers.
