Removing rust from the tank
Posted: Mon Apr 10, 2006 5:01 am
by Max
Does any body know if a little surface rust in the gas tank will heart anything ? This happened when I was wet sanding the tank after the paint job and some water got inside the tank.
Posted: Mon Apr 10, 2006 9:11 am
by pope
Max,
Two things will help, if it is only a little rust: Buy a bag of steel bearing balls, with tank off of bike, remove fuel sender unit, close all openings with duct tape or some type of cap, fill tank about a 1/4 with gas or better yet a solvent, insert balls in main gas cap, install cap. Shake the tank by hand. This loosens up any tough rust. Repeat, remove all of the balls and old solvent or gas, then rinse with fresh gas.
If it is not a heavy rust: simply put a good fuel filter in line from the petcock to the carbs, but don't cheap out, buy a good one that will keep the fuel clean and make sure that the filter is clear so that you can see what is happening and when to change or clean it.
Lastly if it is really bad rust there is a product called "KREEM" gas tank sealant. It is specifically made for problems like this. I've used it before. It is a good product and you would want to follow the instructions that come with it.
Doug
Posted: Mon Apr 10, 2006 5:50 pm
by Finnpaso
Any info in internet about this "KREEM" ??? :confused:
Posted: Mon Apr 10, 2006 11:37 pm
by delagem
As Mr Mackey says on South Park, Rust is bad, um'kay? A little surface rust will eventually lead to a problem.
KREEM is a sealant that puts a "Tank within a tank" inside your fuel tank. It is available two ways, a 3 part kit including the etching solution (Muriatic acid I think?), some MEK (Methyl Ethyl Ketone) to remove the water, and the Kreem itself. It is also available as just the Kreem.
I have heard of very bad results from just using the Kreem, I think it's from people just Kreeming over the rust. Eventually it lifts off and either clogs the fuel filter, or the carbs if you don't run a filter.
I have had excellent results with the 3 part kit, on several different bikes. My YSR80 had holes in the tank so bad I thought it was unuseable; that was 10 years ago and it's still holding well!
I used a handful of nuts and bolts instead of ball bearings, then shook the bejezzus out of it for half an hour. Then just etched, cleaned, and Kreemed it. The stuff is pretty good. It's available online or at any decent bike shop in the States.
Posted: Tue Apr 11, 2006 1:37 pm
by jcslocum
Look up POR-15. Supposed to be better than Kreem.
Be careful cleaning as to not make a spark. If you can see the rust, scotchbrite on a stick or or something and scrub it off to clean bare metal.
Posted: Fri May 26, 2006 9:52 pm
by ducaustin77
Take your tank to Rusteco in Long Beach. They have the best rust removal techinique known. It doesnt etch the tank nor harm the pant on it. I had it and it worked great. I never sealed it afterwards and still no rust.
Austin
