Spark plug cable
Posted: Mon May 22, 2006 11:29 am
by ansim
I'm thinking about to change the sparkplug cable to new ones.
The old ones are pretty stiff now and probably not changed.
I've done the electric upgrade for the coils and it works great.
Does anyone know if there are something special to consider or can I select whatever there is available?
//Anders
Posted: Mon May 22, 2006 7:28 pm
by Mark
Hi Anders,
Buy 3.0 Ohm Dyna Coils, have a bracket made and order Magnecor sparkplug leads...
Mark
Posted: Tue May 23, 2006 12:58 pm
by dave906
Check out the coil and lead combinations available from Silent Hektik. They have about 2 or 3 sets of varying price and claim to offer increased performance.
Helps if you speak/read German as there is no English web site. I managed to make my way thru the site by copying text blocks into an on line translator.
They also have no email contact - fax/phone/letter only. A bit low tech but but the products are reportedly good quality.
Dave
Posted: Tue May 23, 2006 1:32 pm
by paso750
Anders,
the original cables cannot be seperated from the coils so if you want to use other plug cables you`ll also have to go for different coils (others than already mentioned are from ANDREWS)
Plug cables are also supplied by Nology
http://www.nology.com/
The ones from SilentHektik are great, I own them myself. Their coils though are 2.7 ohms and only recommended with their own programmable ignition units. I had a discussion with them longer time ago and they recommend not to use them with the original CDI units as these could be damaged. Didn`t happen to me, but this should be said anyway.
rgds,
Gerhard
Posted: Wed May 24, 2006 1:05 pm
by BikerBard
### I've been running Harley Screaming Eagle wires on my Paso for some time now with no problems at all.
DG
Posted: Wed May 24, 2006 1:21 pm
by paso750
with the original coils ?!
Posted: Thu May 25, 2006 3:04 am
by BikerBard
### Yep. Nearly 500 miles so far and she's running better than she did before. (the old plug wires were a piece of crap tho, so not a fair comparison.)
DG
Posted: Thu May 25, 2006 9:18 am
by ansim
BikerBard wrote:quote]with the original coils ?!
DG[/quote]
How did you do the change?
//Anders
Posted: Fri May 26, 2006 3:41 am
by BikerBard
Anders,
the wires just need to be cut to length and the new ends crimped on.
DG
Posted: Fri May 26, 2006 7:35 am
by paso750
the question is rather about the connection to the coil as plug cable and coil seem to be one piece. I cannot see how they can be devided.
Gerhard
Posted: Fri May 26, 2006 7:54 am
by Jules
I separated the original leads from the original coils by.......brute strength. A lot of wiggling and unscrewing and pulling and they came out. I fitted yellow NGK leads and plug caps to the original coils and the bike has felt a lot 'crisper' since.
Jules
