wich other disc set?
Posted: Fri May 26, 2006 10:01 am
by desmodave
I have it from this forum that the 1991 750 ss clutch disc set is same as the paso is this true also i have just been told by baines that a 906 is the same so come on lads wich models are compatible maybe we should submit a table of dry and wet then everyone of us can get parts easier and speedier. desmo dave.
Posted: Tue May 30, 2006 1:55 pm
by Duc750
There is only one clutch set available now which I believe fits the 750, 906 Paso, early 750ss (with the dry clutch) and some of the 851's the part number ends in 19A.
I do not think the clutches were originally the same but Baines will be about right if thats what they are telling you (I had a long conversation with them about it a couple of weeks ago)
If you want a second opinion try Tony Brancatto at Brancatto engineering or WM Snell. John at Mdina Italia should also be able to tell you. (I alternate which one I pester so I don't wear out my welcome with them)
:laugh:
Posted: Tue May 30, 2006 7:48 pm
just get a catalog from a shop supplying Duc parts and you`ll find out in 5sec.
ie. the Surflex S2076 which is suitable for:
750 SS 1991-1992
750 Santamonica 1988
750 Paso-Paso Europa 1986-1989
851 S 1988
888 Racing 1989
900 SS 1989-1990
900 Paso 1989-1990
http://www.ducati-kaemna.de/cms_de/kata ... tikel=1112
then you know
Gerhard
