Valve specs on 750?
Posted: Fri Jun 02, 2006 4:31 pm
by izaakb
Can't seem to find this listed anywhere..
what are the intake/exhaust valve specs on the 750?
is there a concensus on if this is sufficient?
i picked up a set of F1 spec valves and seats, and I just happen to have some heads laying around...
Posted: Fri Jun 02, 2006 7:01 pm
by paso750
inlet
0.15mm
exhaust
0.20mm
this is from the owner`s manual. Interesting is that the Paso 750 workshop manual indicates 0.10mm (0.0039in) for both.
A german manual for 750SS/900SS states 0.08-0.10mm for inlet and 0.10-0.12 for exhaust valve.
Haynes for SS/Monster 600/750/900 says 0.10-0.12mm for inlet and 0.12-0.15mm for exhaust valve.
No intention to confuse, just wondering about all these differences.
Posted: Fri Jun 02, 2006 8:10 pm
by izaakb
I was referring to the valve diameter, not the rocker gaps.
Anyone?
Posted: Fri Jun 02, 2006 8:15 pm
by paso750
oh, sorry.
diam. 41mm inlet (1.6141in.)
diam. 35mm exhaust (1.3779in.)
why don`t you just check the workshop manual ?
Posted: Fri Jun 02, 2006 8:20 pm
by izaakb
paso750 wrote:oh, sorry.
Honestly, I looked but it was taking hours to scan through the pages.
Thanks for the info, you answered my question -- they are the same as the F1's valves. I guess I have a spare set now, assuming the stems are the same length.
by 750pheonix
Izaakb the manual is available for anyone to download... or you can buy it on cd off ebay for cash. I recommend the download.
there's the service manual and the Eper diagrams (schematics) of all the components.
Posted: Fri Jun 02, 2006 8:59 pm
by paso750
mine are 43mm/37mm but there`s nothing original anymore.
For an original or midly tuned engine the original valves are fine.
Posted: Fri Jun 02, 2006 9:07 pm
by Duc750
:funny:
Show off !
Posted: Fri Jun 02, 2006 9:28 pm
by paso750
of course not
In fact keeping the original valves didn`t make sense anymore at a certain stage :screwy:
However, I`m just saying the original combination of valves, cams etc is fine. So changing them does only make sense if you also change/modify other (interacting) parts.
Posted: Sat Jun 03, 2006 7:28 am
by Finnpaso
Porting means a LOT, when talking about valves! Also cams !!!
I have noticed this in my 907IE very clearly.... ST2 cams, porting, open air inlet, open exhaust, etc... :laugh:
