Page 1 of 2
Clock solution???
Posted: Sat Jun 24, 2006 7:17 pm
by f1steveuk
I have been told, but how reliable the info' is I don't know! that the internals from a Fiat Panda 4X4 (sqaure shape not the new one) is a perfect repair for a Paso clock. Could this be true
Posted: Sat Jun 24, 2006 7:59 pm
Could be that`s written in a current ebay auction, right
I`ve never tried it, but the Ducati parts interchangeability side said:
Paso clock can be replaced by fitting the printed circuit board from some Fiat models such as the Mirafiori, Tipo and Jaeger
Gerhard
Re: Clock solution???
Posted: Sun Jun 25, 2006 9:14 am
by 750pheonix
f1steveuk wrote:I have been told, but how reliable the info' is I don't know! that the internals from a Fiat Panda 4X4 (sqaure shape not the new one) is a perfect repair for a Paso clock. Could this be true
the information is slightly dubious, as the clock from the 4x4 panda is identical to all the other pre2003 pandas... time piece and console.
Posted: Mon Jun 26, 2006 6:23 am
by redpaso
Ride the road don't watch the clock
take it out & leave it out
Posted: Mon Jun 26, 2006 7:00 pm
by Rogero
No truth in rumour that 906 owners need a clock to check their 0-60 mph times :laugh: :laugh:
Posted: Tue Jun 27, 2006 9:18 pm
by persempre907
redpaso wrote:Ride the road don't watch the clock
Then, the clock discharges your battery. :funny: :funny: :funny: :funny:
Clock solution???
Posted: Wed Jul 12, 2006 11:59 am
by JWilliam
I removed the original clock and placed a battery operated clock inside the instrument box with wires out to a 1.5v battery. Lasts for months before I have to change the battery. I had to cut down the new clock for fitment but at least I have a second hand now.
Posted: Tue Apr 28, 2009 2:17 pm
by pasotibbs
Old thread I know,but if you didn't know already the clock from a Fiat Uno (common in Europe)has the same Circuit board ,I've repaired 2 or 3 this way in the past.
Posted: Tue Apr 28, 2009 6:25 pm
by Finnpaso
btw, what is problem in Paso clock, as all mine works still well ???? I maean, is it plastic sprockets inside clock? or circuit board?, components? what?
Posted: Wed Apr 29, 2009 12:20 am
by Tamburinifan
Welcome, pasotibbs (from V11forum
Nice to se you here.
Posted: Wed Apr 29, 2009 8:13 am
by pasotibbs
Finnpaso wrote:btw, what is problem in Paso clock, as all mine works still well ???? I maean, is it plastic sprockets inside clock? or circuit board?, components? what?
With mine and I suspect with others it goes like this....
Battery is low and bike only just starts, go for ride to charge battery,
while riding the battery light comes on,
pull over and discover this is because main fuse has melted !!,
fix fuse and notice clock has now stopped working,
Strip clock and find resistor has fried !!!
Basically make sure the main fuse holder is a good quality design,keep it clean and don't ride your bike if the battery is almost flat, charge it first !!
Posted: Wed Apr 29, 2009 2:14 pm
by Finnpaso
Very strange... I would suspect that if that resistor blows from clock, it cant burn main fuse, but surely it can burn that circuit fuse where clock is.... But i dont have 906, so i dont know how fuses are in that bike. Another quess is, that if there are some charge problems, there can be then overvoltages in some circuits and it can burn that resistor from clock....
Noticed just, that 750 Paso dont have "main fuse" (3 different fuses surely!), like 906 (40A), 907IE (30A), ST series (30-40A), etc have and i think, "main fuse" is just that between regulator and battery + terminal.
EDIT: Propably You think, that main fuse is that biggest 15A fuse in 750 Paso between battery and key lock(ignition switch)? Ok, in 750 Paso we can call it " main fuse"
Posted: Thu Apr 30, 2009 9:05 pm
by Mc tool
mine was knackered when I got the bike so I fitted an oil pressure gauge instead .As some one had already spilt brake fluid on the lens I made a new one so that got rid of the clock knob hole
Posted: Fri May 01, 2009 1:16 pm
by duke900
Mc tool wrote:mine was knackered when I got the bike so I fitted an oil pressure gauge instead .As some one had already spilt brake fluid on the lens I made a new one so that got rid of the clock knob hole
How did you make a new lens for the dashboard??
mine is cracked....
do you have pictures of your new improve lens???
Posted: Fri May 01, 2009 5:30 pm
by Finnpaso
I am also very intrested...
