mikuni carb conversion problem
bavarian
I have a 1988 Ducati 750 Paso that I converted to 38mm Mikunis with dynajet stage two jets and Uni pod filters. I have searched the entire site and even the lenghtly write up I found about the conversion doesn't address my problem. The entire conversion went smoothly, that is until I turned on the ignition and fuel started pouring out of both float bowl overfill drains. I even installed a fuel pressure regulator and no fix. I removed the float bowls and cleaned everything out and even removed the floats and needles which were clean. I reinstalled it and I still have the same problem. I have the fuel line from the regulator hooked up to the the upper line, and the bottom line is hooked to a drain line as per the aforementioned lengthly write up that covers the conversion on this site. I hope somebody can give me some insight as to what I did wrong or need to check. Thanks!
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
bavarian
mikunis
I didn't connect the return line. Which spigot on the right side of the tank does the line need to be attached to; the forwrd or aft one? Thanks!
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
bavarian
I now have everything hooked up according to the site and still have the same problem. I even installed the pressure regulator in where the Y splits off and goes to the carb inlet. Could the floats be bad? They aren't full of fuel so I don't think they leak. The carbs came from a '95 900ss. I can hear the fuel being pumped into the tank so it definitle is bypassing some fuel? What could I be missing here?
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
Duc750
- year: 1993
Take the float bowls off and check the housing where the overflow drain screw fits
If you or a previous owner is particularly ham fisted these can crack quite easily which gives exactly that effect.
(I speak from experience
Have you checked that your floats do actually still float ?
You can do that quite easily when you have the float chamber off
bavarian
I'll check the drain screws, but wouldn't it always leak if the the bowls were cracked? They only leak gas with the pump on, the bike will run fine with the pump off until it runs out of the fuel that is in the float bowls. I'm going to check and see if the floats actually float as well...
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
pikey
bavarian
I would like to measure the float height, but as yet nobody on this forum has come up with exactly how float height is measured and what the exact specs are. Until then I guess I'll keep fumbling around in the dark until the day a say forget it and slap the old webers back on. It sure would be nice to ride it this year...
Nick
'74 R75/6
'88 750 Paso
'04 R1150RT
'74 R75/6
'88 750 Paso
'04 R1150RT
pikey
I have used the straight side of a digital caliper to measure the float hight on my cb 750. you can get a honda float gauge from various websites, and it will work just as well as any other. I dont know the correct float hight for the mikunis, but I can find out for you. you have to turn the carb sideways so the float is hanging straight down, and the bottom edge of the float must be perfectly straight with the the surface that the bowl touches. then measure the hight between the surface that the bowl touches and the bottom of the floats. now you know your float hight. once you know the correct hight (which I will try and find the correct hight), you can adjust float hight by gently bending the tab which the floats connect to, either up or down to compensate the diference.
Now with that said I have never been inside my mikuni 38mms
but my good friend, the previous owner, has. I will ask him the correct float hight, and if there are any special tricks for those carbs. I hope this helps.
good luck!..........pikey
- Harigeharry
This might help:bavarian wrote:I would like to measure the float height, but as yet nobody on this forum has come up with exactly how float height is measured and what the exact specs are. Until then I guess I'll keep fumbling around in the dark until the day a say forget it and slap the old webers back on. It sure would be nice to ride it this year...
http://www.buschandbusch.com/ducatisuite/jetkit.html
It was a great help with my build up:
http://forums.ducatipaso.org/viewtopic. ... pic&t=1105
