Reg rec question
Posted: Sat Jul 22, 2006 3:44 pm
Afternoon all, I'm just throwing this open to the forum for your opinions
My charge warning light is not working but my charging circuit is putting out a healthy voltage (13.2 volts at 1800 revs and about 13.98 at 4500 revs no higher any further up the rev range
The pink wire running into the white wire on the reg rec via the multi plug is showing the battery voltage so the feedback loop is working and intact
Its just there is then no voltage goign to the Pink wire on the dash which operates the light - actually thats a lie there is 0.5 V with the ignition on but no motor running and zero with the motor running
I'm assuming this is a problem internally with the reg rec or could it be just a simple breakdown of that pink wire ? :umm:
all suggestions gratefully recieved
Duc
Duc
