Bin Your Weber
Posted: Wed Aug 16, 2006 3:25 am
Hi All,
Have owned a 750 Paso for the last 2.5 years and it has had the original Weber carb. After installing a Holly fuel pressure regulator in the first few months and regularly cleaning the carb it all ran fairly well, no real complaints. Recently I’ve obtained a set of Mikuni 38mm carbs and accessories from a 1994 900SS. Gave these a good clean and fitted a Dynajet Stage 2, jet and needle set along with some pod type air cleaners. (Along with all the major service items like timing belts, valve shim adjustment, the JS wiring mods, etc).
Anyway, the bike started easily and after a short warm up settled down to a steady 900rpm idle. Have now had a chance to take the bike out for a 50km run, to sort out any problems that might appear. There were none. The change to performance is amazing, it does not even seam like the same bike. It accelerates in 5th like it used to in 4th with absolutely no hesitation.
The intention behind the installation of the Mikunis was to remove the stumble/hesitation around 4000 rpm which was a feature of the Weber. Not only has this completely disappeared, but there is a substantial boost to overall performance. It will even sit and idle at the traffic lights and not stall.
In summary if you ever had any doubts about replacing the Weber with Mikunis or Dellortos etc, then forget them, do the change, you will never regret it.
The intake roar when giving it full open throttle is addictive, you just want to keep doing it. Suggest you get some.
Regards,
Fraser.
Regards,
Fraser.
