Page 1 of 3
Dual bulb headlight?
Posted: Thu Oct 05, 2006 11:54 am
by Rlbol
I recently saw one on Ebay. The item description said it would fit an paso/907. Does anyone know anything about this? It looked like the normal square head light but had 2 H4 bulbs?
Posted: Thu Oct 05, 2006 4:53 pm
by ducapaso
Mike "the keeper of this madness" has posted something about this... search in the classified posting
Posted: Thu Oct 05, 2006 7:18 pm
by Finnpaso
I have put to both my Pasos dual round headlights with 2 X H4 bulbs, but i dont have fotos in Gallery yet.
Posted: Thu Oct 05, 2006 7:45 pm
by jcslocum
It's supposed to be a better lens with better light on the road.
Posted: Thu Oct 05, 2006 10:01 pm
by redpaso
THE US spec Yamaha FZ-750 (1987) used the same headlight casing but with dual headlights inside. Apparently they slot in no mods needed. This is something I plan doing after some brake upgrades. These were still available new from Yamaha approximately 12 months ago.
Here is a picture of Pope's Dual Headlight Paso.
Posted: Fri Oct 06, 2006 12:12 am
by Rlbol
Thanks everyone I will try and find one.
What is the deal with the mesh below the headlight?
Posted: Fri Oct 06, 2006 2:17 am
by jcslocum
You should have the mesh on yours.
I stand corrected!
Posted: Fri Oct 06, 2006 11:59 am
by KillerB
907 Pasos are mesh free.
Regards, B
Posted: Fri Oct 06, 2006 1:55 pm
by persempre907
Are the Yamaha FZ 750 EU headlight different from the US spec? No matter, it would have work better than the OEM unit, I guess.
Posted: Fri Oct 06, 2006 7:54 pm
by Finnpaso
I agree You Jon, 907IE is MESHfree Ducati !!! :funny:
Posted: Sun Oct 08, 2006 9:43 pm
by Stingray230SX
that kind of updates the look a little as well!!
i think that the headlight on the paso is the only thing on it that "dates' it as an older bike
probably best to go ahead and do the relay and power the light directly from the battery when putting in this new dual bulb assembly, correct?
anybody got a part number for this lens assembly etc...?
doug(who wants to find one of these,can ya tell)
Posted: Mon Oct 09, 2006 7:15 pm
by Finnpaso
There is ONE bigger problem with Dual H4 headlights: If You use both BULBS TOGETHER, then not enough current from charging system to battery!!!! I have seen this in my 907IE and after 65 kms drive, i have to ask one honda driver to push me with jump start, when i stopped to fuel my bike, so BOTH bulbs cant use same time. 2 X high beam, or 2 X low beam takes TOO MUCH to 907. I KNOW THAT.... Anyway "look" is much better now.... Btw, i put switch to handlebar to dissconnect another bulb and i use ONLY both bulbs , when REALLY NEED and short time then!
That P7 ECU NEEDS enough voltage to function, like should. There is voltage "looking" wire and if voltage drops too low from battery, then ECU cuts off! I know, i know.....
Dual Headlamp conversion
Posted: Mon Oct 09, 2006 8:00 pm
by Shelboss
This headlamp assembly is listed as P/N 1LJ-84303-A0-00 on this site and sells for $132.17 plus shipping, best price I've found new.
http://shop.yamaha-motorcycleparts.com/ ... /home.aspx
The models it fits are Yamaha 86 FZ750S, 87 FZ700T & TC, and 88 FZ750U, the R models are different. It comes from Japan and is currently back-ordered.
Dual Headlight
Posted: Thu Oct 12, 2006 12:27 am
by Shelboss
I just finished testing the power output of my alternator. I used a clamp-on current meter on the alternator wire just ahead of the 30 amp fuse. To test for potential output of the alternator, I ran the headlight without starting for about 10 minutes, then started the bike. Altenator output was 20.4 amps at 14.3 volts, or 292 watts. I imagine with a dead battery it might approach 350 watts as speced. I then let the battery charge up and ran it with the high beam at 3K rpm. It drew 186 watts. I believe there is 100-150 watts to spare on these bikes. The previous owner of my bike ran a heated vest and grips, which add up to 90 watts if constantly on. The wiring to the regulator and alternator have been beefed up and an aftermarket regulator put in, so proceed with caution when adding load, lest you'll be pushing it home
Dual Headlight power
Posted: Tue Oct 17, 2006 3:50 pm
by Shelboss
The stock bulb for the dual headlights is listed as a 35/35 watt. Is anyone using it with the stock wattage?
