STUPID IGNITION PICKUPS!
Posted: Tue Oct 10, 2006 5:40 am
by pikey
well heres the story: started the paso up the other morning, and had a lot of trouble getting her started. once I got her running, the motor sounded kind of rough, but I was still half asleep and just figured it needed to warm up. As soon as I started rolling I knew something was indeed very wrong. There was NO power at all. I then realized why the motor sounded so strange: She was only running on one cylinder! so I finaly made it to the motorcycle shop I work at. first thing I did was put new plugs in, and checked for spark. sure enough the lower cylinders coil was not sparking. so I swapped plug wires and checked spark, and it appeared that the same coil was stil not firing. so then I swapped the lead wires to the coils and the suspected coil fired. Long story short, I eliminated the possibility that the coils or igniters could be bad, which left the ignition pickup for said cylinder. I test both and the lower cylinders pickup was no good. so its either the wire leading to the pickup or the pickup itself. any suggestions? any body know where I can find a set of pickups? all help is appreciated!!!
-pikey
Re: STUPID IGNITION PICKUPS!
Posted: Tue Oct 10, 2006 1:36 pm
by Desmo_Demon
pikey wrote: any body know where I can find a set of pickups? all help is appreciated!!!
You can get the part numbers here....
http://forums.ducatipaso.org/viewtopic. ... tit&lid=18
Contact your local Ducati dealer and see if they are still available. If they are not, call ProItalia and see if they have any in stock.
http://www.proitalia.com
Hope this helps.
Posted: Tue Oct 10, 2006 8:14 pm
by pikey
Thanks for the help! I still have to check the wire and the pickup itself. I hope its just the wire, but with my luck who knows. thanks again!
-Pikey
