And yet another new owner
Posted: Thu Oct 12, 2006 6:50 am
by betenoire
Friends:
I just acquired a 1988 Paso 750 with just about 14000 miles.
I bought it despite the fact that it runs a bit rough. It tends to backfire, won't hold its idle when coming to a stop, and has a pretty bad flat spot at just around 6000rpm. I had read enough online to expect that carb problems are typical of the model series.
I have the bike at home and have done a teardown of the body panels. The carb had a rebuild kit in it 2000 miles ago, and that was over one year ago. The cam belt was replaced, but there is no indication that the valves were done. I just removed the tank, set the idle to 1500rpm and ran some carb cleaner through the motor.
The bike seems to be in good condition, and everything seems present.
The flat spot is still there, and so is the stalling, but stalling problem has improved. Please let me know if anyone has any helpful ideas. I am not a mechanic, but I am a fair tinkerer. My plan is to get this bike running well and looking good for spring.
Thanks in advance,
Brett
Posted: Thu Oct 12, 2006 3:21 pm
by jcslocum
Brett,
Work you way thru the FAQ at the top of the forum for what most of us consider the major issues.
If it's the Weber carb the flat spot can be quite hard to get out but you can try. The FAQ again has some ideas. The idle issue can be fixed and will take some timkering. The rebuild is where I'd start to make sure all of the proper parts were put back in and the jetting isn't all over the place.
The cam belts need to be changed every 2 years or 12K miles. Valve adjustment should be done every 6K miles. Check http://www.ducatisuite.com for instruction on how to do this task.
Just shout if we can be of any further help.
