996 regulator
Posted: Sat Nov 25, 2006 1:26 pm
by h1a
Hi.
Last time my regulator break down my local dealer fitted a regulator from a 996 Biposto (partno: 54040131A) the charging is working great, the only problem is I lost the charge warning light because of the different wiring. Dos anyone have a sugestion on how i can hook up the lamp again :confused:
I have mounted a cheap type voltmeter so i can see how the bike is charging so it is really not a big problem but i would anyway prefer that it was working as it should.
Håvard
Re: 996 regulator
Posted: Sat Nov 25, 2006 1:33 pm
by persempre907
h1a wrote:Hi.
Håvard
Hi Havard,
when you fit the new style 3 phases regulator the battery light is lost.
You can't do anything for it.
Posted: Sat Nov 25, 2006 1:36 pm
by Finnpaso
Its just so! There is NO anymore that wire for warning light in "new type" regulators, but that Voltage meter hookeed sometimes is not so bad idea.... :thumbup:
Posted: Sat Nov 25, 2006 1:54 pm
by h1a
Ok, thanks :thumbup: that was what I suspected anyway, I have been studying the wiring diagram :confused: without finding any solution to it.
Håvard
Posted: Sat Nov 25, 2006 2:31 pm
by jcslocum
It's what we in the USA call an "idiot light". All it means is that it shows when something might be wrong. No details of the problem. The volt meter is a better solution in the long run.
Posted: Mon Dec 04, 2006 1:58 am
by tztag
The new "retrofit" reg/rec kit that Ducati sells just doesn't have the instrument lead. The aftermarket reg/recs I've seen do.
Also- I couldn't get the new Ducati reg rec to fit in the stock location, and I spent hours on it. I ended up mounting it under the headlight by modifying the aluminum plate they supplied with the kit.
tag
Posted: Mon Dec 04, 2006 6:09 am
by persempre907
tztag wrote:The aftermarket reg/recs I've seen do.
Do you mean the Electrex RR51?
Yes, the "idiot light" would work.
But, I've say this idiot light is not too much idiot. It tells you have come back to your home quite quickly.
:funny: :funny: :funny: :funny: :funny: :funny: :funny: :funny: :funny: :funny: :funny:
