907 brakes
Posted: Sat Dec 02, 2006 9:26 am
by tewsy
g-day 907 owners,can anyone tell me how much protrusion from calipers should front pistons be on front brakes.
Posted: Sat Dec 02, 2006 10:02 am
by Finnpaso
:confused: :confused: :confused:
Do You mean, "how far out" can those pistons come FROM calipers(brake sylinders)????? Or did You maen disck measurements, or what? :confused:
Posted: Sat Dec 02, 2006 1:32 pm
by tewsy
yeah,how far can pistons come out from calipers.thinking maybe pads are worn but only pistons on one side are out ,caliper is touching new disc on one side.
thanks for reply.
Posted: Sat Dec 02, 2006 2:10 pm
by jcslocum
Sounds like the caliper piston mught be stuck on the side that is not coming out. Maybe a rebuild is in order.
Posted: Sat Dec 02, 2006 2:13 pm
by Finnpaso
There are not any specs about, "how far those pistons can come", if enough far, piston pops away from cylinder. You have one "groove" in middle of pad(disc side), so You can see from that groove, what is limit of pad! But seems, that U have to pull out all pistons and make cleaning job to Your sylinders and pistons to work, like should. How much U know about that job??? If not so much, let it to someone, who really knows, what need to do. propably have to find also new seals to calipers and surely need to know, how to get air away from system after cleaning EVERYTHING.... Anyway its not so wise to open totally caliper sides from each others. All MUST be clean, before rebuild pistons to cylinders. Seems, that only one pair of pistons are working normally and some "shit" is causing thiskind problems.... All this is only quessing, cause i havent seen closely Your systems... :thumbup:
Posted: Sat Dec 02, 2006 9:19 pm
by tewsy
thanks for help will advise outcomes.
Posted: Sun Dec 03, 2006 2:57 am
by wilbur
Is the offset of the new disk the same as the old disk? That may be the problem. You could shim the caliper if you need to move it a bit.
Posted: Sun Dec 03, 2006 9:11 am
by Finnpaso
Yes, that can be problem. I taught, that SURELY he use normal rotors, which have right offset.... Remembering, that all that time Ducatis had same offset, also many later modells, like 851/888, SS and Monsters... :thumbup:
Posted: Sun Dec 03, 2006 10:38 am
by tewsy
if you look from front of bike at the left caliper, the disc is just clear of the left side of caliper.would shimming the front axle bolt help?
Posted: Sun Dec 03, 2006 1:39 pm
by jcslocum
Are they the stock rotors?
Shimming it one way may make it fit on one side but cause it to be too tight on the other.
Posted: Sun Dec 03, 2006 8:46 pm
by Finnpaso
Little strange, if ONLY "left" seems to be out of measurements??? :confused: Normally there is not ANY shim plates in front axle... :evil: Can You take some close fotos??? My mail: finnpaso@gmail.com can load fotos. If someone need those from me, i can resend easily, but then need address surely...
Btw, are rotors original???? I mean designed to 907IE ....
Posted: Fri Dec 08, 2006 10:27 am
by tewsy
problem solved,pistons on one side of calipers were tight.meaning other side was doing most of work.when tightened axle bolt adjust right fork out a fraction then tighten lock bolts,freed up pistons and all seem ok.calipers now line up disc in centre
thanks to everyones helpful info
