Manuals, magazine articles and other downloads
Posted: Sun Jan 07, 2007 3:08 pm
Hi everyone,
most of the files below can be found also in the document section of the main site.
I`ve uploaded the files on an external hoster, too just in case the site should crash and files get lost as it already happened in the past.
I don`t know if the place I`ve uploaded the files has a traffic limitations, if so pls retry another time.
Also if the pages don`t show in your browser hit the refresh button.
If you own magazine articles, brochures etc and have the possibility to scan them let me know via pm.
Note: if you follow one of the links below and then click on the download button you may get a 'register'/'log-in' pop-up. Ignore that. Just wait a second and you'll get a message from your webbrowser asking if you want to open or download the file.
Brochures and magazine articles:
brochures
Magazine articles and reviews
dutch
english
french
german
italian
spanish
General:
Ducati Paso buyer`s guide
https://app.box.com/s/2fhq2uukm6t3hc14mboele7zupkdgq2e
Ducati Belt-Drive Two-Valve Twins - Restoration and Modification
(Paso/Sport part & appendix - production numbers/ technical specs - only)
https://app.box.com/shared/nzfez3vs4q
Haynes manual SS/Monster (for Paso/Sport relevant parts only)
https://app.box.com/s/dcym4984vznkj8tpacp6
Overview of clutch discs packs & disc order from SURFLEX
https://app.box.com/s/w2y6okcblz8ve8xtxr45
https://app.box.com/s/0jou7koxsuy3fd8vwhcmratvm8w0m3yo
engine doesn`t start - fault finding chart (doesn`t cover specific 907i.e. issues)
https://app.box.com/s/x8fmn1brzuya97x8z44z
Service bulletin regarding gear selector mechanism - all Ducati models
https://app.box.com/s/ccqi4o1hoelpn458dffawwf51kiq20cs
Carburation:
Weber manuals
https://app.box.com/shared/adnox7gm4n
Mikuni manuals
https://app.box.com/s/gslivfnzo4d3ak79cqs1
Dellorto manuals
https://app.box.com/s/tpt2q4mfepejq6ab91wx
Keihin FCR carb infos/manuals
https://app.box.com/s/sbjnzj00pvd4mmemr0cf
fuel hose specifications
https://app.box.com/s/ut9pl8qs48zin0rbwf016cal8vtybvb2
Valve timing:
Adjusting valve timing (cam dialling)
https://app.box.com/s/ihqtb1fw1jmt9xo55jbw
about valve timing and camshaft specs
https://app.box.com/s/pst9p706lhf9nvrf8kzpm6kcr5zefayb
timing disc:
http://www.bevelheaven.com/downloads/Un ... ngDisc.bmp
diy TDC finder
https://app.box.com/s/tysuio186n95lhlj1pdu
Electrics:
charging system (stator & regulator/rectifier) fault finding chart from ELECTREX/ElectroSport
https://app.box.com/s/l97psjbqeswn9dk403ki
https://app.box.com/s/jzxzqy9x27xkeu4w2kdc
ElectroSport ESR515 and Electrex RR51 installation
https://app.box.com/s/r16ixjegwfl7aq3ybd0c
Diode testing guide from ElectroSport
https://app.box.com/s/92vrafnr2ajarh65j2pf
Shin Yo regulator installation
https://app.box.com/s/y5n81gem88ul3ymp6a0v
Repairing the ignition switch
https://app.box.com/shared/4evp1px5be
Repairing the starter solenoid (shown on a Pantah engine)
https://app.box.com/shared/njqjcaortr
Repairing the starter motor (shown on a Pantah engine)
https://app.box.com/s/pgaj1d0jmggrksbq7qqg
Casting your own front turn signal lenses
https://app.box.com/s/5zijl9qr6uqwkn77tcdi81kxcwk4zu77
Suspension & steering:
Marzocchi M1R fork manual
https://app.box.com/s/50abzqguic881iuynxr3539i8xshvqzq
Marzocchi M1R fork stop rings dimensions
https://app.box.com/shared/8r1zg2tlln
Marzocchi DuoShock service manual
https://app.box.com/s/yaishmk894lgxoazkxzj
new rear excenters for 17" conversion (17mm axle from a SS can be used, hence no need to machine the wheels to fit larger bearings)
https://app.box.com/shared/t89r5dk3cx
bar risers drawings and CAD files + video
https://app.box.com/s/930pnwe1c197vdapzcz1
Chain sliders:
Drawings/dimensions
The large one on the swingarm
https://app.box.com/file/1804808058062? ... ifb78ns15k
https://app.box.com/file/29621657237?s= ... 7kbplk018o
The small ones:
https://app.box.com/s/u3egke9rsug5g7x55oe6odfy75fxkz98
Brakes:
tutorial on how to convert to 4 piston Brembo brake calipers incl. drawings and CAD files
https://app.box.com/shared/ugl1ifxe4n
brake adapters and some other info on 17" wheel conversion of P750/906
https://app.box.com/shared/lscrqbkkbx
brake adapters for 17" wheel conversion (calipers with 65mm mounting hole distance)
https://app.box.com/shared/lzd6kxnkgk
brake adapters for 300/320mm discs on Marzocchi M1R fork (calipers with 40mm mounting hole distance)
https://app.box.com/shared/gj6cbxn48w
Brembo P4 caliper dimensions
https://app.box.com/s/33qzf3qc1xyait4v1hvz
Luggage carrier systems:
mounting instructions for NonFango luggage carrier rack for 906
https://app.box.com/shared/0g50o8zqco
mounting instructions for Givi luggage carrier rack for 750/907ie
https://app.box.com/shared/4go2jdg17i
instructions for Givi universal mounting kit (for Givi wingrack carrier systems)
https://app.box.com/shared/t7ior2l62u
Hepco & Becker luggage rack (german description only)
https://app.box.com/s/te0lt03wrp15cfodnoyp
Ducati Paso 750:
P750 owner`s manual US version
https://app.box.com/s/pc5ghj6fdd7znlua884q
P750 owner`s manual multi language version
https://app.box.com/s/uuk8jf3je62bbu63q36o
P750 owner`s manual - California version (w/ Marelli Digiplex ignition)
https://app.box.com/s/88gjll751geb0iwxiz0n
P750 workshop manual
https://app.box.com/s/ged1902olfpn1i1lq5oa
P750 parts catalogue
https://app.box.com/s/jnbqq0149p83zybzu96sg812qbxpaa62
P750 wiring diagram (in colour)
https://app.box.com/shared/q1jdmz8ub9
P750 wiring diagram - California version (w/ Marelli Digiplex ignition) (in colour)
https://app.box.com/s/91fqn279mpwnv4kezfv6
P750 wiring modifications
https://app.box.com/s/waxvk1l9g47phfybd6n9
P750 Weber 44DCNF-107 and -110 & jetting
https://app.box.com/s/heep8qtaxti97872wqia6z7037bbhxv3
TÜV Bescheinigungen für Alternativbereifungen (german TÜV approval for alternative tires)
Metzeler/Bridgestone
https://app.box.com/shared/hft4b2yedq
Avon
https://app.box.com/shared/gq6hrzi9s4
https://app.box.com/s/nqed9t99elyhi2dnradnzn2jwgib6kp3
Ducati Paso 906:
P906 owner`s manual US version
https://app.box.com/s/05bef79ua99adyspg5do
P906 workshop manual
https://app.box.com/s/mai2335dh4vl43q0efqn
P906 parts catalogue
https://app.box.com/s/anb97obn37pareletpkc
P906 wiring diagram (in colour)
https://app.box.com/s/cuv8nragt3z1vi0pw9pz
P906 wiring modifications
https://app.box.com/s/xzkocz2e7zcomsg40t7f
Weber mod and jetting for the P906
https://app.box.com/shared/q1x77snl9g
coolant reservoir modification
https://app.box.com/shared/ou0yii8jnc
Ducati 907i.e.
907i.e. owner`s manual
https://app.box.com/shared/kjkfr06a8c
907i.e. workshop manual (supplement to the 906 wsm)
https://app.box.com/s/jna5o7iamr6p6tq6fspq
907i.e. parts catalogue
https://app.box.com/s/lctqs86c8pvnxjp965v9
907i.e. wiring diagram (in colour)
https://app.box.com/shared/3elasen7q7
907i.e. wiring modification
https://app.box.com/s/64zvqpl6sf303gt44wu6
swingarm/brake caliper bracket pin - drawing
https://app.box.com/shared/jvp2dyz1h3
repairing the fuel pump
https://app.box.com/s/i8zgqnd7bdye1rofk1bg
adjusting CO trim
https://app.box.com/s/b2go9ga3sq6iq07lvg9a
adjusting TPS (throttle position sensor)
https://app.box.com/s/5a9zws9e2w31yhldlq1t
Unbedenklichkeitsbescheinigung für Reifenumrüstungen (german documents of compliance for alternative tires)
https://app.box.com/s/2bikt9sc0p1knplq1jrpha3stcp2jbhq
left and right swingarm decals (printable pdfs) (these are not for the P750/906 as the necessary chain slack is different!)
https://app.box.com/s/oo896rmygkkgl6gzj08cklpdd5uun0wy
documenti di omologazione (italian homologation documents)
https://app.box.com/s/vxb8chbfpan45ru0q9qqg4b5xr0dygri
Ducati 750S:
750 Sport owner`s manual
https://app.box.com/shared/pbgnkjcxlq
750 Sport workshop manual
https://app.box.com/s/s691kou2nhlb3b41bfcy
750 Sport parts catalogue
https://app.box.com/s/7p0bygcer4dy1bvwvl2j
750S wiring diagram in colour
https://app.box.com/s/d95nkk3uis04nzqdato1
750S wiring modifications
https://app.box.com/s/6mqf34acdyjfs9yhrc0m
https://app.box.com/shared/6kbvqrfbh5
https://app.box.com/s/szatal5pfpbhqx2uidymo9bzn78p06q0
https://app.box.com/s/e84h1xb3ri7l0slwlf3ok3geb850hf5r
Ducati 900SS '90:
900 Supersport owner`s manual
https://app.box.com/s/s6d7qjaaite4dkps1o8672egq5fse0gb
900 Supersport workshop manual
https://app.box.com/s/7u0incfpwbpxw1dmyqv4
900 Supersport parts catalogue
https://app.box.com/s/8rb7ayuuif2qs7qncgo5kejzuwld1h3j
900 Supersport specs
https://app.box.com/s/9edju4oizdzps0e4eigx6wwnohiti3bf
900 Supersport frame, swingarm and fork dimensions
https://app.box.com/s/x8e93h3dojj0wq8dzicth2dv2hb6es62
900 Supersport wiring diagram (in colour)
https://app.box.com/s/rqlews1vt1onid6b96bi
Miscellaneous :
Twist of the wrist 1&2 (pdf books)
https://app.box.com/s/8np98tuqzwzjv860j1xz
Reducing advance timing
https://app.box.com/s/iut6yms5nzsj7ofop60h
Primary gear locking wrench (diy)
https://app.box.com/s/16nf3ousc6f6vh06hkts
Alternator cover puller (diy)
https://app.box.com/s/5d4z2km8p9pewuk2765l
Toolkit contents overview
https://app.box.com/s/rgqeymo6uc8ezcphkiyw
Spark plug overview for big bore and HC kits
https://app.box.com/s/ed37m2l97ijfbvel33ve
Spark plug heat range crossreference chart
https://app.box.com/s/25we7ooqtng6ktcgwhxv
Overview of Marelli Digiplex units
https://app.box.com/s/ganl7i3ent8e6mznlc5g
Öhlins shocks service manuals
https://app.box.com/s/pdfatxijjvjcbnwca9jw
https://app.box.com/s/0dfl2mi1twovxonh98g4
Öhlins steering damper service manual
https://app.box.com/s/ur52u0iyc4os9u8377m1
label showing setup of California bikes / emission control regulation
https://app.box.com/shared/p9x1uzvrsl
Ducati Paso 750, 906 & 907i.e. Info zur Abgasuntersuchung (info for emissions control, relevant for Germany)
https://app.box.com/shared/eovf78q2dg
desktop background picture Ducati 906 - 1280x1024
https://app.box.com/shared/xg6l5ggjej#906_PC_background
Crankcase breather article
https://app.box.com/s/ispwmx1hd13pfn54iqj4
2 articles on exhaust systems
https://app.box.com/shared/4rd2q3kljs
article on engine oil
https://app.box.com/shared/h9fod6nisn
Italo Shop Neuss '93 Katalog
https://app.box.com/s/jakc6x6k2zmxqc1mgrmgbgfvm4cp7mfo
test of Moto Morini 350 Dart (Paso lookalike)
https://app.box.com/shared/myrqgq2f0o
Ducati 851 888 manuals
https://app.box.com/s/8szdrpd317tsje263a16
Remote oil filler (drawing & pictures)
https://app.box.com/s/kohcxdnssrfnyywofb8q4289mqehizfy
Ducati 750 900 Supersport manuals ('91-'97)
https://app.box.com/s/23wv4czer9cvqqkp2woh
Ducati 750 F1 manuals
https://app.box.com/s/wq12jqesd32h5g017za2
Ducati Indiana 350-650 parts catalogue
https://app.box.com/s/z4fit23rjaud3qyf7bdq
Ducati ST2 manuals
https://app.box.com/s/mqr5iyf0av3nk1dt9dyn
Cagiva Alazurra 350-650 manuals
https://app.box.com/s/yx3dyrf2im8b2mlkx3k3
Cagiva Elefant manuals
https://app.box.com/s/58lxodw7ml4qeg86oxsv
Cagiva Freccia 125 C10R C12R manuals
https://app.box.com/s/nn436yoe1v0cdz2pxwftd2ll69ymnp0e
Reparaturanleitung Monster 600/750 & 900 ab ´93 (german only)
https://app.box.com/s/vyb1ckcgzys9s60myp8s
other motorcycle manuals
http://www.carlsalter.com/motorcycle-manuals.asp
http://www.manualedereparatie.info
http://www.pdfmotomanual.com/index.php? ... 8&lang=ENG
Ducati Paso videos:
https://app.box.com/shared/1k6dyg6hj6
have fun
brochures
dutch
english
french
german
italian
spanish
General:
Carburation:
Weber manuals
Mikuni manuals
Dellorto manuals
Valve timing:
timing disc:
diy TDC finder
Electrics:
Chain sliders:
Drawings/dimensions
The small ones:
Brakes:
Ducati Paso 750:
Avon
Ducati Paso 906:
Ducati 907i.e.
adjusting CO trim
Ducati 750S:
Ducati 900SS '90:
Miscellaneous :
Ducati ST2 manuals
Ducati Paso videos:
have fun
