Oilcoolers
Posted: Wed Jan 12, 2005 12:17 pm
by Johan_Oden
Hi!
I was wondering how you take of the oilcoolers on the side panels? I just can“t figer it out...
Posted: Wed Jan 12, 2005 6:13 pm
by Skins
Gidday Johan
The coolers have rubber caps on top and bottom, and just press fit into the panels. They can be very sticky to get out. You have to pull them out, best from the inside, so you dont damage the oil unions and, on the right, the electrical connections. Best to take the left one off first, and then tie and hang the cooler with string up to the front fairing support strut. Then you can see the right cooler and tie string to support it before taking off that panel.
When reassembling, a light coating of oil on the ruibber caps will help, and aid future removal.
Posted: Wed Jan 12, 2005 6:41 pm
by Johan_Oden
Thank you!
Posted: Fri Jan 14, 2005 3:41 am
by c-dogg
just wondering, im am sans an upper bumper on one of my oil coolers. an air filter is doing the duty there right now but it is definitely not a long term fit. does anyone know where i could pick up one of those bumpers?
Posted: Fri Jan 14, 2005 4:38 am
by Skins
c-dogg,
phil sutton - of
desmocycle@paradise.net.nz - is quite likely to have one, if you can't find one closer to home, and don't mind organising payment and freight from here. Have you tried a local dealer?
