mounting exhaust connection
Posted: Mon Jan 22, 2007 9:33 pm
by ducapiero
Hi guys in this period i plan to mount new 2 in 1 collector,i buy two new gaskets,but i don't understand how i have to recover the ring that hold the exhaust on the cilinder...
give me the light for this upgrade
Piero
P.S.
i chose a carby arrow at 45 angle
Posted: Wed Jan 24, 2007 4:43 pm
by ducapiero
help me i don't know how to procede!!!!
Posted: Wed Jan 24, 2007 5:45 pm
by Desmo_Demon
I don't understand what you are asking. Are you wanting to know how to remove the retaining ring from the head or how to remove the ring from the exhaust pipe?
To remove it from the head, you just remove the two nuts that are mounted on the head studs and wiggle it off the studs. In some cases, I've seen the nuts to be over-torqued, which results in the ring being bent and stubborn to come off. Heavy rust could cause problems pulling it off of the studs, also.
To remove the retaining ring from the pipe, you just separate the ring from the flange on the exhaust pipe, and the two half-rings will fall out. If they are badly rusted, they may be sticking, but shouldn't be a problem to get off. Once the half-rings are removed, the ring just slides off the pipe.
Did I answer your question?
Posted: Wed Jan 24, 2007 8:36 pm
by ducapiero
Posted: Wed Jan 24, 2007 9:21 pm
by Desmo_Demon
ducapiero wrote:on my manual there can be 4 pieces i think.but on my bike i don't see this....mine paso is of 88 on the new exhaust there isn't lock ring. :
Can you get a picture of it? From what I recall from my '87, the flare on the end of the pipe is either welded or it is a rolled section of the pipe. Then, you have the two half-rings that fit into a recession on the retaining ring. It's fairly straight-forward and the same as my '98 ST2.
