Wheel Bearings and Axles
Posted: Wed Jan 24, 2007 4:05 pm
I'm getting ready to change the wheel bearings on my Paso, and I noticed something that caught me offguard. The bearings for both wheels are the same (20mm id x 42mm od x 16mm width - I believe it is an SKF #63004-2RS1), but the issue that I see is that the front axle is 17mm and the rear is 20 mm. :umm:
Looking at the front wheel, I noticed a bushing that takes up this 3mm difference for the smaller axle. According to the Parts Manual, it shows the "distance piece" between the two bearings to have a shoulder for the bearing to fit over. If this is the case, how do I knock out the front wheel bearings? It doesn't look like I can knock them out like I did the rear wheel bearings (which were completely worn out). If the "distance piece" is two pieces, I assume I just knock out an inner sleeve and then proceed to remove the bearings and spacer as I did with the rear wheel.
Anyone have any insight?
Note: The original 20mm x 42mm x 16mm bearings are fairly uncommon and cost between $30 and $45 USD EACH. I noticed, though, that a much more common, and cheaper 20 x 42 x 12 bearing is available (4mm thinner - and has the same loading and rpm specs of the 16mm wide bearing). I'm going to see if I can use this thinner bearing by making some 4mm spacers to make up the difference in width (one on each side of the wheel). It'll be the difference in $80-$100 USD if I can use the 12mm wide bearings. I'll update at a later time.
