My Mikunis are now filtered.
Posted: Mon Jan 29, 2007 9:52 am
Hi
As I have written before, I have mounted my mikunis, and now created an air filter solution. The foam filter are from "Twin Air". The tubes are two 90 degree bends from my local "Bits and things for car dealer"
. The duc tape will be replaced with a rubber socket. There has been a bit of adaptation for the intakes, but no big deal. I don’t know yet if it works because of the weather in Denmark, but at idling and at reving it, it seems ok. But a road test will determine there function.
Se the last few pictures on the below link.
http://www.motorcykelgalleri.dk/html/ga ... sp?ID=1846
Regards
Klaus
Denmark
PASO 750, 1990
Regards
Klaus
Denmark
PASO 750, 1990
