Spark Plug Failure/New Spark Plug Leads
Posted: Wed Feb 21, 2007 6:09 am
Friends:
Twice after working on the Weber carb I have attempted to take the bike around the block for a test run. Both times the bike ran, but shortly after the run began the bike started to run on only one cylinder (No. 2).
Inspection revealed no spark. Replacing spark plug fixed the issue. However, new spark plug seems to have developed the same problem.
As you can see from an earlier post concerning timing issues, I was unable to verify the low speed timing due to the mark jumping around so much at low speed. The timing is fine at high speed. John Slocum replied and said that the issue may be voltage at the plug, and to replace the leads. Given the repeated failure of the spark plug, this seems reasonable as a starting place.
Here are the two questions:
1. Has anyone encountered a loss of spark once the bike is warm? What might account for a loss of spark once temparatures on the bike approach running temparature?
2. Inspection of the spark plug leads and the parts manual make it unclear whether the leads are built into the coil. For obvious reasons I have been reluctant to just pull until it comes out, but I did try removing the plug wire from the coil. It wasn't going to just pop out like the usually do. I've never seen a plug hard wired with a spark plug lead before, but there are several things on this bike I haven't seen before. If the leads do come out, how does one get them out without damaging the lead or the coil?
Thanks for the help.
Brett
Brett
