The pickups - Hall/magnetic or what
Posted: Mon Mar 12, 2007 12:00 pm
by ansim
Hello paso freaks and owners,
Does anyone know what type of pickups the Paso have, Hall, magnetic or something else?
BR
//Anders
Posted: Tue Mar 13, 2007 7:47 pm
by ducapaso
They're magnetic, and they're placed inside the left cover of the engine. Be careful in removing that cover, as it requires a special tool as extractor.
Posted: Wed Mar 14, 2007 6:59 pm
by Finnpaso
.... and those pick ups MUST be very well adjusted.... :evil:
pickups
Posted: Sun Mar 18, 2007 8:18 pm
by ducinthebay
There are two different types on the Paso's and Sports.
Two pickups in the case, and a single pickup version that mounts from the outside of the case at the 2 o'clock position with two little screws. The latter was common in the California bikes, as there is no way to adjust the timing. As mentioned, the gap is critical. The single pickup type is set with little shims. The ST2 motor is similar in regard.
The single pickup version used the Magnet Marelli 2s computer, which is a finned aluminum box under the seat with a big wire connector and a vacuum hose attached. About the same size as your voltage R/R.
