906 17 inch wheel conversion again
Posted: Mon Mar 19, 2007 6:56 pm
Hi all, have a chance of buying some 907 parts, before buying (parts are not local) I need to know what will fit first. I already have a pair of 851 17 wheels and tyres, the rear 180/55 17 tyre
1. Does the longer 907 rear swing arm have the same damper/spring suspension mounts as 906, I ve looked at 851s and 600 monster, arm looks similar to 907 but spring/damper mounts are different.
2.Can I use my 906 rear brake caliper and disc on 907 swing arm, is caliper mtg bracket in the same place???
3.Will 907 front fork tubes fit 906 fork hangers, or do I need to change whole front fork, or can I reuse 906 fork with 17 wheels. I noticed that 906 discs will not fit 17 wheel.
4. Can I use reuse my 906 wheel axles
plus any other comments you may wish to add. I will be keeping all removed 906 parts
thanks Peter
thanks Peter
