Wiring upgrade Choke/ idle issue
Posted: Wed May 09, 2007 5:59 am
by staticvoid1975
Hello All,
I purchased my Paso a few ago and am I quite happy I did so. However, I did have some issues with batteries being unexpectedly sucked dry and leaving me stranded. I did the wiring upgrade and I am happy to report that it worked out great and I now have strong spark at the coils at the massive dip in voltage I encountered previously is gone. However, when I apply the choke now the bike only revs at 1500, when before I believe it was up aound 3000. Also, after I have had the bike on choke for a few minutes and return it to idle it drops below 1000 and often dies. Any ideas on why the electrical mod affected this and what can I do to fix it?
Thanks for a hugely helpul resource for this bike and I hope to learn much more.
Ben
Posted: Wed May 09, 2007 12:17 pm
by jcslocum
The two are not connected so it must be something that was moved or "upset" during the wiring changes. With the improved spark it will run better at idle and fire easier.
I hope someone else has an idea. Weber or Dellorto Carbs??
Posted: Wed May 09, 2007 3:54 pm
by ducapaso
About the battery brying, test the voltage regulator: an incorrect charging, can happen a long heating of the battery (and injuries tho the ingition boxes! :eek: :mad: ) See the 750 f.a.q. digest about that.
hmmm
Posted: Fri May 11, 2007 3:33 am
by staticvoid1975
Well, it looks like I have a bad regulator. Which may explain the residue on the exterior of the battery....hmmmm. I brought the wiring back to its original state and it ran as should. That said, I brought the bike up to 5000 and it hovered around 15.75 V and juice started boiling out of the top of the battery. I am gonna sort out the regulator before I try the wiring upgrade again. It took about two minutes to take it back to original! Anyway, thank for everyones help.
Ben
Posted: Fri May 11, 2007 4:26 pm
by persempre907
:mad: :mad: :mad: :mad: :mad: :mad: 15,75V!!!!!!!!!!!!!!!
Regulator burnt!
Buy an Electrex RR51 one!
Posted: Fri May 11, 2007 8:21 pm
by Finnpaso
Regulator problem! But check also wiring from inside left cover... AND ALL charging system wires !!!! :thumbup:
ordered
Posted: Fri May 11, 2007 11:31 pm
by staticvoid1975
I ordered the electrex rr51 today. I am going to take the time to sort through all of the wiring,contacts, etc. while I wait for it to arrive.
Thanks,
Ben
Posted: Sat May 12, 2007 8:45 am
by persempre907
Best choice, but also check all the wirings, as Antti told, 'cause the bad electric contacts can do many damages.
Posted: Sat May 12, 2007 3:11 pm
by streetsurfer
So, do you think you just dropped power to one cylinder causing the rpm drops?
Posted: Sun May 13, 2007 10:56 pm
by staticvoid1975
I am not sure what caused the rpm drops. I was getting a reading of 11.8 to each coil and there was equal pressure coming out of the exhausts. I will try the wiring mod again once the regulator/ wiring situation is tamed.
Posted: Mon May 14, 2007 7:25 pm
by jcslocum
There is a crossover in the exhaust, so checking the end of the muffler to see if one cylinder is running doesn't work.
Posted: Mon May 14, 2007 7:51 pm
by streetsurfer
Yes, better to check the temperature of the header pipes (before the X).
