Questions
Posted: Mon Jan 31, 2005 11:56 pm
by pompone
I have three questions without response. I need your opinion:
- Wich do you think is the best brake pad?
- What do you think about Bitubo rear shock?
- Is possible to fit a pair of BMW R850R or K100RS 16v Brembo 4 pistons calipers in Marzocchi fork?
Posted: Tue Feb 01, 2005 7:47 pm
by Skins
Vesrah pads work well enough for me, pompone. Can't help with your other two questions, sorry.
Posted: Tue Feb 01, 2005 9:10 pm
by pompone
Thank you Skins for your information.
Posted: Tue Feb 01, 2005 9:42 pm
by mike
i have a friend that has the dual-pot brembos on his bike.
it's done with a caliper adapter like this one (this is nicolas bike)
Posted: Wed Feb 02, 2005 8:59 am
by paso750
I use a simple Bitubo shock. Can`t say anything bad about it. It was the cheapest replacement i found a couple of years ago. For me it is a little bit to hard, but the spring tension is easily adjustible.
The only "problem" with this shock is that the rebound adjustment lever is on the bottom. The lever is a little bit too long and touches the shock leverage. As this is just a screw with a plastic cap on it`s head it`s easy to remove and shorten it. Just be careful to make a mark wat which position the adjuster exactly was when you remove the screw so you get to the exact same position when you reassemble it.
After about 4 years the paint of the shock is a bit bubbly and coming off on top. Maybe this is because of low paint quality in combination with the heat from the rear header, I don`t know.
Anyway I think it`s o.k. and as the price is only a part of what the original new part costs it`s even better :)
Onve in a while you`ll find an original shock on ebay.
Check ebay.de there was one a couple of days ago.
Gerhard
Posted: Wed Feb 02, 2005 9:53 pm
by pompone
Thank you Gerhard. I'm thinking to buy a new Bitubo shock now.
Posted: Mon Feb 28, 2005 4:32 pm
by ducapaso
did anybody calling me?
I fit on my dukess 17" rims and 320 disks, so I had just to fit the calipers in the right point... But if you still have the original brake disks i think you'll not find a pad that can fit well on your brake disk.
Otherwise you can search for 280mm floating brake disk for 16" rim and work on these
Have a nice ride, Nicola
post script
Posted: Fri Mar 18, 2005 6:25 pm
by ducapaso
the manifacturer for floating disc is DISCACCIATI, and the spare part is aviable in italy for 213euros + taxes
or you can search a good mechanical customer able to build the internal part of the disc right for the 16" rim
