Page 1 of 2
To FIM or not to FIM...
Posted: Tue Jun 19, 2007 12:27 am
by Cybermunster
Guys & Gals,
Any advice, suggestions, tips or stories on the following; I have a 1992 907 IE with Staintune slip-ons and a K&N air filter. The bike has 15K miles and is now very well maintained.
1) Should I add the FIM chip?
2) What would be the benefits?
3) What can I realistically expect?
Best rgrds,
Cyber
Posted: Tue Jun 19, 2007 12:29 pm
by persempre907
You can find all the info about the FIM chip in their website.
http://www.fuelinmoto.com.au
There is a specific chip for the 907.
Here there are the results.
Posted: Wed Jun 20, 2007 3:29 pm
by Finnpaso
FIM is best chip, cause it can be finetuned by FIM software(needs dynoruns with FIM software). There have been also some others, like FBF and also some "usa original 907 chip"(what is worst, if U have open pipes,=need richer mixture).
Btw, is here any "gals" :lick: :lick: :lick:
I am very courious to hear, WHY "NOT go to FIM"
Cyber, do U have P7, or P8 ECU ??? ...And are U sure of it ?
Posted: Sat Jun 23, 2007 8:33 am
by Tamburinifan
Are that 907 chart accurate? Seems pretty low which also the one f 851 is:
Posted: Sat Jun 23, 2007 1:27 pm
by persempre907
Those charts show the HP at the rear wheel!
Posted: Sat Jun 23, 2007 8:33 pm
by Tamburinifan
Ducati used to measure at rear wheel, 851´s were around 90Hp.
I find it hard to believe 68 f 851.
907 I know too little about yet.
Posted: Sun Jun 24, 2007 4:33 am
by persempre907
Uhhhmmmm,
yes, really also the difference between 907 and 851 would be too little...
Posted: Mon Jun 25, 2007 9:41 pm
by Tamburinifan
Mine is -92 in the papers but w black Brembos so maybe a -91, right?
Does mine have an early P7 or what? How do I check this?
If I have P7, will I need this Additional Memory Board (see quote from Sigma below) to use the FIM fully?
FIM redesigned the operating system in the Weber ECU's unit to add extra functionality not supplied in the original Weber software. Many of the operating parameters were switched from 'constants' to 'variables' allowing a tuner to adjust them while the engine is running. Early P7's required an Additional Memory Board to permanently change the fuel parameters without actually reprogramming a new chip. Later computers had either EPROM or Flash memory which was unused by Weber; these were used to store extra fuel corrections, RPM telltales and so on. (Note; these additional parameters only work with FIM Chips as the factory Eproms ignore these locations.)
Posted: Tue Jun 26, 2007 4:24 am
by Finnpaso
Check that code from from ECU! Whats it???? I am quite sure, that U have P7 and U can use FIM EPROM normally in that P7, BUT IF U want to change mapping inside FIM eprom AND STORE THAT CHANGING to EPROM, then You need AMB. AMB keeps changes(made by FIM software with flat top!!!) inside ECU after You turn ignition key to OFF mode....
Without AMB P7 ECU cant remember changes!
Posted: Tue Jun 26, 2007 10:36 am
by Tamburinifan
OK.
Thx, Antti!
Posted: Tue Jun 26, 2007 12:18 pm
by Finnpaso
Btw, where U are located in Sweden? At least here is one guy from east coast writing sometimes here...
Posted: Tue Jun 26, 2007 2:01 pm
by Tamburinifan
Gothenburg.
Posted: Tue Jun 26, 2007 6:09 pm
by Finnpaso
Ok!
I have friends in Malmö :laugh:
P7 have these marks in label:
IAW 043 / 04
WU 43.07 / 20A_28
I have 2 x P7 ECUs and both have exact same label/marks
Posted: Tue Jun 26, 2007 11:55 pm
by Tamburinifan
OK, will check my ECU, thx again, Antti.
Here is very good info:
http://www.sigmaperformance.com/weber-ultimap.html
FIM Chips
Posted: Fri Jun 29, 2007 11:21 pm
by LudeDuc
I put in the Ferracci stage 1 chip when I put on my Cobra F1 pipes on my 1991 Paso 907ie and there was a noticeable improvement in performance. Has been running great for two year.
You can get the chips here:
http://www.ferracci.com/store/cart.php? ... etail&p=98
